Road bar mounted friction shifter?
Hi,
Does this exist? A friction shifter, either with index mode or just friction with enough throw to operate an 11 speed mtb or road mech and a clamp that fits on a 31.8 road bar flat at the top?
Just a little something I am mucking about with :lol:
BigdummySteve
Re: Road bar mounted friction shifter?
Post by BigdummySteve »
I’m sure microshift will do something.
Microshift make a lovely shifter, but its on a 22.2 clamp.
https://www.microshift.com/en/product/sl-m11/
I wonder if I can swap the clamp to a 31,8 somewhere
lune ranger
Post by lune ranger »
ssnowman
Post by ssnowman »
Paul Components do one I believe.
May satan walk with you
numplumz
Post by numplumz »
Find a mtb shifter that is removable from the original clamp, and adapt onto a correct size clamp...maybe 😁
numplumz wrote: Thu Feb 25, 2021 4:14 pm Find a mtb shifter that is removable from the original clamp, and adapt onto a correct size clamp...maybe 😁
exactly where I started :grin:
I used a band on front mech hanger as the clamp
for example
https://www.tredz.co.uk/.M-Part-Front-D ... _45217.htm
they can be had cheaper but do size at 31.8 so a perfect fit
Mine was used for a SRAM X0 left hand shifter and did not require any bodging [ not much lever clearance mind]
I'll have a think about that clamp ta.
Pauls / Microshift look nice, but at 200 quid (more or less) for a shifter, I may as well buy some Apex kit. The idea is that its cheap cheap. Along with easy and simple to use.
ripio
Post by ripio »
Not cheap but you could possibly mount standard bar end shifters with friction mode to these mounts
https://www.sjscycles.co.uk/gear-spares ... ion-black/
But shifting across an 11 speed cassette in friction mode would maybe be a bit finicky.
BigdummySteve
£3 now were talking
kvragu
Post by kvragu »
https://youtu.be/3yNZswI0If4?t=626
@10:26 these guys mounted an oldie clamp on the handlebars, much like the above suggestions.
numplumz
Post by numplumz »
kvragu wrote: Fri Feb 26, 2021 11:13 am https://youtu.be/3yNZswI0If4?t=626
Going to get me one of those handy bamboo sticks :lol: :grin:
Could be a new market for Stuart, carbon photo prop sticks
