GPS mount
GPS mount
I've got a Garmin bar mount ... but when fastenened to the bars it doesn't behave itself and I can't fasten it to my stem because it's too short and the wrong shape. I've knocked this up which seems to work well enough but wondered if anyone has any neater solutions ?
Re: GPS mount
Just been pondering this myself.
I went for one of these for mine
http://www.ebay.co.uk/itm/400397883227
I already had a little computer on the stem, and keep toying with the idea of shortening it so figured this would do the job.
It also fits my light next to it and gets it above the wires etc
Re: GPS mount
I'd looked at something like that Drew but it's just like fitting it to the bars, ie, I find the Garmin mount rotates.
Re: GPS mount
Is that the Edge mount or the Dakota mount?
Edge mount is peerless in my experience, Dakota mount benefitted from a wrap of innertube. The Fargo has a nice long stem to fit it on. It was awful on the swift's flat bars (polished finish to boot!)
Re: GPS mount
Old bit of old inner tube between the bars and the mount cures that issue. Bit of electrical tape over the raised catch stops the ejecting as well.s8tannorm wrote:I find the Garmin mount rotates.
- gairym
Re: GPS mount
any tips on how to stop the annoying rattling as mine stays on (though I have some cord attached as back-up) and doesn't rotate (yet!) but it does make a hell of a noise!
Re: GPS mount
Liberal amount of electrical tape to pack the mount out a bit so it does rattle. Over the raised catch at the bottom of the mount works for me (credit to HUX for letting me into the secret)gairym wrote:any tips on how to stop the annoying rattling as mine stays on (though I have some cord attached as back-up) and doesn't rotate (yet!) but it does make a hell of a noise!
Re: GPS mount
I do have electrical tape on mine, but haven't really tried it in anger yet on anything other than rough back roads!
But as the father in law is visiting this week, it may be an opportunity to escape for a few hours to give it a good test!
Whilst my girls are playing making "tracks" on the Dakota is becoming addictive!
Re: GPS mount
S8tannorm - could you not make a low profile version of what you have already, maybe using a piece of plate instead of the tube? Then cutting some small notches in it to grip the cable ties and stop it coming off.
- The seasons blow away, but the love is just the same -
Re: GPS mount
Not able to contribute much to a solution, (except perhaps double-sided carpet tape between mount and bar?), but I've not yet experienced my Etrex 30 rotating (though it is a tight fit on a 90mm, 10 degree rise stem).
Does it use a different mount to the Dakota?
- 99percentchimp
Re: GPS mount
I used a trimmed down Park Super Patch http://www.parktool.com/product/super-patch-kit-gp-2 inside the mount - the patch stays put and as it's a bit flexible it seemed to make a good job of stopping any vibration. Seemed to work very well in an eTrex mount.
That looks like a good solution Stu
Conquistador of the pointless
Re: GPS mount
My standard Dakota mount seems to stay put fairly well - I've had neither the rotating nor the "self-ejecting" problem.
Re: GPS mount
Ive got the 62s and use the garmin mount for this cable tied to my 90mm stem...its solid never moved and as for the rattling as chew says use tape-it tightens everything up nicely.
Re: GPS mount
I reckon it would fit on your stem Stu!
