Midge nets
- Bearlegged
Midge nets
Hi folks, has anyone got any advice on what makes a good midge (head) net?
I've seen warnings that cheaper ones may stop mosquitoes, but smaller, midgey things can sneak through.
Two candidates here:
https://www.ultralightoutdoorgear.co.uk ... dnet-p6815
https://www.ultralightoutdoorgear.co.uk ... adnet-p179
The Sea to Summit one promises 310 holes/cm2 versus 178 holes per cm2 for the Coghlans one. Am I right in thinking more holes = finer mesh = better protection?
Re: Midge nets
I've got the S2S Ultra Fine and it kept them out. Their own details say it's made for midges
https://www.seatosummit.co.uk/products/ ... h-headset/
Smidge also make one
https://midge.myshopify.com/collections ... e-head-net
Cheaper, but it's green I think which some say is harder to see through.
Re: Midge nets
Yep, more holes, the finer the mesh. Also worth considering that darker colours are said to be more attractive to midges.
- Bearlegged
Re: Midge nets
Thanks folks.
Curse my naturally dark and handsome looks!Also worth considering that darker colours are said to be more attractive to midges.
Re: Midge nets
I use a cheapo 'Highlander' one. Stops midges no bother but mozzies can sting through any net. You have to wear a brimmed cotton hat round which you head net hangs so that the mozzies can't get to you.....
Re: Midge nets
I got a Trespass one for a quid. Works fine - have tested a lot!
Re: Midge nets
Mountain Warehouse one works fine.
edit as we don't have midges but other winged bitey stingy things I took to wrapping my cycle helmet in my head net to stop things dancing on top of my head this summer.
Points for double use?
Re: Midge nets
Dee says the nets from MW are fine ... will there be midges she said
Re: Midge nets
WILL YOU STOP TALKING ABOUT EFFIN' MIDGES! I'M ITCHING JUST READING THIS THREAD
- UnderTheRadars
- Location: Stourbridge/North Col of North Worcestershire Alps
Re: Midge nets
Have a look at this thenwhitestone wrote: ↑Fri Sep 04, 2020 10:47 am WILL YOU STOP TALKING ABOUT EFFIN' MIDGES! I'M ITCHING JUST READING THIS THREAD
https://youtu.be/WzUlj6eTehA
Re: Midge nets
We just carry the sort of front brimmed caps that roadie cyclists wear. Very light and compact. It works well.
