Acepac bar bag
Acepac bar bag
I need to replace my Wildcat bar bag and I like the look of the Acepac bar bag. Will it fit around another non-Acepak roll or does it only attach to their own roll bag or directly to the handlebars without a roll? If you see what I mean...
Re: Acepac bar bag
Really like mine. Its got two clip straps on the edges and a centre strap the uses hooks. The only thing the acepac bag has is a bit of velcro in the centre. But it's not necessary, the straps will pull really tight.
It's a really solid harness. Seems a more secure than the restrap equivalent.
Re: Acepac bar bag
I bought the 16 litre one and it fits my MYOG harness just fine. I've not used a dual end before but find it really handy. I don't pack it full so there is space to store food when you resupply. Looks well made too. Very happy with it.
Re: Acepac bar bag
Do you mean the roll / dry bag or the clip on pouch thing?
I got the clip on pouch thing to use stand alone. It’s a useful little bag but didn’t see an way to easily attach it to my wildcat harness if that’s what you mean.
Re: Acepac bar bag
That’s exactly what I mean. I want to attach it to, or around, my Wildcat harness and roll. I’d be happy if it just had straps long enough to all the way round a 20L roll bag and then lock back to itself - much like the Wildcat accessory bag does.
- stevewaters
Re: Acepac bar bag
I just got bought one of the Acepac bar bags from Stuart. I am using it in conjunction with a Wildcat Lion harness and Alpkit 12L dry bag.
For the "top" attachments, I have tied a pair of (yellow) thin cord loops threaded through the Wildcat top clip straps and I put small (2.5mm) oval maillon rapides on the Acepac straps to connect these loops to. - These connections take less than a minute to undo if you need to remove the bag entirely. The bottom of the acepack bag has a "hook" strap that I hook onto an old small climbing sling attached to the bars and routed around the back of the wildcat harness. This bottom hook strap can be tightened up to make things snug.
The 3 photos posted below were from a trial run. I can get the whole system a fair bit "tighter" now. - I hope to use it on the Cairngorms 300 loop in a fortnight.
Last edited by stevewaters on Tue Sep 01, 2020 12:02 am, edited 10 times in total.
- stevewaters
- stevewaters
Re: Acepac bar bag
Sorry, misunderstood what you were getting at.
Re: Acepac bar bag
That’s great - very useful photos!
I did have to look up what a maillon rapids was though.
- Escape Goat
Re: Acepac bar bag
I love mine too. Got the extra bag on mine and it's solid. So good I'm thinking on selling my wildcat harness.
- BigdummySteve
Re: Acepac bar bag
Quality bag, I cut the fittings from shoulder strap and used Velcro to fit them to the bars. You can then use the points which would fit to the Acepac harness, the lower point I loop under the fork crown and use the c hook to cinch it tight. It’s rock solid used like this
- Escape Goat
Re: Acepac bar bag
Oooh, you got a picture of that set up?
- Escape Goat
Re: Acepac bar bag
Also,
You got a picture of your extendy bar or a link to it? It's looks more solid that what I'm going to use.
- stevewaters
Re: Acepac bar bag
It's this one from SJS Cycles: https://www.sjscycles.co.uk/accessories ... -anodized/
They have various other ones here: https://www.sjscycles.co.uk/accessory-f ... ts/?page=2
Here's a pic from the side:
- Escape Goat
Re: Acepac bar bag
Brilliant. Thanks for that. Will check them out.
- BigdummySteve
Re: Acepac bar bag
- Escape Goat
Re: Acepac bar bag
Nice!
