Oh Arse!
- BigdummySteve
Oh Arse!
Thought I’d give the bike a clean as it’s had some use the last few weeks.
No dramatic impact that I can remember recently, I did notice a drop in pressure
WTB Ci31 roughly 2 years old.
Scary thing was I hit nearly 45 mph on the way home this morning.
Re: Oh Arse!
That's the trouble with cleaning your bike
I didn't notice the cracks in my Stans Arch rim until I cleaned the bike, if I'd left it dirty I'd probably still be riding on that rim now* and none the wiser
* Unless of course the spokes pulled through the cracked eyelets.
Re: Oh Arse!
i dont think i will bother with carbon rims.
Re: Oh Arse!
You better also not bother with alloy rims. Just imagine, they break unexpectedly!
I know that feeling. Blew tyres and damaged (alloy) rims at high speeds and at the moment it's very, very unfunny that often resulted in more carnage, like snapping frames and bones.BigdummySteve wrote: ↑Fri Jul 17, 2020 2:26 pm Scary thing was I hit nearly 45 mph on the way home this morning.
Your experience shows, that carbon not fails the way many think it does. (Fill in necassarily and/or always in prior sentences as you wish if your a carbon sceptic).
Re: Oh Arse!
I think it fails in an expensive way - am I really wrong
Re: Oh Arse!
I usually dented alloy rims on impacts, rendering then useless for tubeless use, even after bending them back into shape.
So, I often ended up getting a new one.
My carbon rims are much stronger where it depends, after a solid ding and damaged tyre, the rims show absolutely no sign of the impact.
I once rode past some over hanging bedrock, slipped and caught the rear on it. I was lucky to ride it out. It damaged multiple spokes and put a soft spot into my carbon rim.
In my experience I would've had to walk home with an aluminium rim - too many spokes had snapped.
I got a new carbon rim through crash replacement for a fraction of the initial price and had the damaged rim fixed professionally.
I'm certain this little slip would've cost me more if it had been an aluminium rim.
Over the years I find I have about 3 x the damage with aluminium rims compared to carbon rims. Yet the initial cost of carbon is not 3 x as much and the financial situation gets even better once they become damaged.
So, in my experience, yes, you're wrong. (Given we're comparing Lightbicycle carbon rims against alu rims like RaceFace Arc, Stan's Flow, DT's, WTB KOM etc.)
Re: Oh Arse!
I suppose you've seen this video of Danny MacAskill trying to destroy a set of carbon rims. https://www.youtube.com/watch?v=VfjjiHGuHoc
- BigdummySteve
Re: Oh Arse!
Yes, seem that video. The strange thing is that I genuinely can’t think of any impact which might have damaged it, I don’t jump/ do backflips etc and run high enough pressures to prevent rim impacts.
- BigdummySteve
Re: Oh Arse!
One glimmer of hope, I’m just inside the 3 year warranty, I struggle to Believe they won’t just dismiss it as crash damage however.
Re: Oh Arse!
That doesn't look like crash or impact damage Steve.
Re: Oh Arse!
Does seem a funny place to crack that, almost looks like a compression / shear fracture (45 degrees to circumference up sidewall) possibly up the line of the carbon weave. Good tip - tell them you were 'just riding along' when it happened - they'll be bound to warranty it!
Re: Oh Arse!
If it doesn't polish out, a bit of duct tape strategically placed will remove all worry.
- BigdummySteve
Re: Oh Arse!
Just riding along, although a classic excuse of the incompetent is more or less the truth. Even though it’s a dropbar bike I’m not shy downhills but hey I’m an old git and not even sure what ‘sending it’ actually involveshtrider wrote: ↑Fri Jul 17, 2020 5:58 pm Does seem a funny place to crack that, almost looks like a compression / shear fracture (45 degrees to circumference up sidewall) possibly up the line of the carbon weave. Good tip - tell them you were 'just riding along' when it happened - they'll be bound to warranty it!
I even phoned pickers up, he gave the spokes a squeeze when I popped in last week so it’s not spoke tension.
Not sure what I’ll replace it with if they don’t warranty it, probably light bicycle carbon.
Re: Oh Arse!
Indeed.
Also what I though when I saw the photo.
Hard if you have to choose between giraffe, elephant and monkey plasters.pistonbroke wrote: ↑Fri Jul 17, 2020 6:01 pm If it doesn't polish out, a bit of duct tape strategically placed will remove all worry.
The elephant did a great job.
- BigdummySteve
Re: Oh Arse!
I took the option of breaking down the wheel, I’ve no working bike now but I would otherwise be tempted to use it , it’ll be ok? If that had let go at 45mph it would be a different discussion.
Re: Oh Arse!
You and wheels are jinxed Stevo mate . What with your record with spokes, hoops, whatever, it's about time you went for the nuclear option. Only £1500 (each!) reduced from £2k. Problem gone. Wallet empty.
Re: Oh Arse!
My experience with carbon rims was similar, never again for me.
Re: Oh Arse!
You are localish to me - can lend you a bike/wheel if need something to keep pedaling with while you sort this out Steve?
Re: Oh Arse!
Just how dirty were they, for you to not notice that?
Re: Oh Arse!
Agreed, it would have been quite a bang in the enclosed space in the back of your vanIf that had let go at 45mph it would be a different discussion.
- BigdummySteve
Re: Oh Arse!
Cheers Andy, may take you up on the offer of a wheel depending on how long it takes to sort.
Re: Oh Arse!
With the added benefit of making your bike a fixie
- BigdummySteve
Re: Oh Arse!
Well I’ve just had a nice email from WTB, apparently they are going to warranty it
Unfortunately the Ci31 rim is longer available, but they can fund the cost of a suitable replacement, I’m having trouble finding a suitable rim , 29” 32 hole 30-31 mm internal
Any recommendations?
Re: Oh Arse!
This a newer version of a rim I have years of use on
https://www.lightbicycle.com/35mm-wide- ... ility.html
Never used these
https://whiskyparts.co/rims/no9-36w
Never used these
