Out Front Mount GPS 64 Using Wahoo Elemnt Roam Mount
Escape Goat
Post by Escape Goat »
I thought I'd share something I found out today. I like to use both Wahoo for it's recording capabilities but I like having OS maps on the go too. I don't like having the GPS 64 to one side, usually on the stem, whilst I could mount the GPS 64 on the stem and the Wahoo on the outfront mount, the aerial covers the screen a bit. First world problems!
There's a plastic plate under the mount, it's removable, I don't know why...but there's holes.
Pop a couple of zip ties through and route it through the Garmin mount
Route the zip ties through here
The curve of the mount needs to be filled a bit, this worked.
Route two more, but zip tie it behind the two others so it doesn't slide off.
And a couple of after the bodge.
Dont forget to tether your GPS to the bars.
