New SON light with power out and a high/low bean (edit/ beam, perhaps)? Sold
![Thumbs up! :-bd](./images/smilies/113.gif)
Magnetic connection is really smart. Just need a suitable connector for the Garmin and this would tidy up my SON dynamo light + power set up by replacing the USB-Werk.
Yep, I switched over to using these which have been working well.
I don't use a Garmin that much but I've always just plugged it straight into the Beacon and it charges fine. I found the connectors useful as I was taking my front wheel off pretty often (for transport). I also found them pretty good stuck on the side of the trail in the dark in the pissing rain fixing a puncture.Lazarus wrote: ↑Mon Oct 30, 2023 5:49 pm You dont need a cache bank as you can just plug your garmin straight into a sinewave* even if the light is on, that said everyone is carrying a battery bank** anyway so its not additional weight
Most bike lights are not the " road legal" German set up but it works fine for me on the road , most of my commute is unlit road. What is that road standard like off road ?
Always good to have more dynamo light options and internal cache is nice feature [ but presumably either large light or small capacity].
* Having never tried [ charge it over night from a battery bank] i can confirm that you can plug a 530 straight into the light and it will charge [worked with both USB only and light on and i was barely moving as just outside on the road.
** i charge this during the day then run the light off it at night for off road [ the dynamo is still on so will still charge the battery bank as you are using it.
I used some waterproof ebay connectors for mine and its a faff with gloves as they are so small but no effort required to connect and they dont come lose that magnetic connector is a good idea but quite pricey for not much real benefit ; i connect mine at the start of a ride [or winter for the commuter] and that is it.
Maybe it's my older Garmin Edge, but if there's no cache battery it powers down when the current stops. The cache regulates it so that junctions on the road, slow climbs etc don't give you the powering down timer message. It's a fault of the Garmin more than anything else. I don't generally take a power pack with me when riding with the dynamo set up I have, I'm charging either Garmin, phone or camera as I ride in the day and I just make sure I have a full Garmin charge shortly before dusk when I go onto lights powered off the dynamo.You dont need a cache bank as you can just plug your garmin straight into a sinewave* even if the light is on, that said everyone is carrying a battery bank** anyway so its not additional weight
I find the standard torch beam pattern more tiring on my eyes on longer rides, the Edelux beam pattern is so good for roads and easy trails, a no going back kind of thing personally. Better for drivers ime too, at least in terms of visibility for me : glare to them ratio.Most bike lights are not the " road legal" German set up but it works fine for me on the road , most of my commute is unlit road. What is that road standard like off road ?
I've turned my brightness up to full and still can't see anything.Boab wrote: ↑Wed Nov 01, 2023 6:20 pm New Lotus eBike, yours for a wallet shredding £20k. Not sure I'd want to strap bags to it...
Oh, you want a bike for rich idiots...? I give you the J.LAVERACK ASTON MARTIN .1R. Featuring "Hidden cables. Hidden bolts.".fatbikephil wrote: ↑Wed Nov 01, 2023 11:15 pm That's slightly perverse - all that tech to make it light and aero but if its got a motor then it will still only do 27kph.
Target audience - rich idiots who want the look but can't be bothered putting in the miles. Yawn.
I wouldn't say no to a S-Works Aethos (Dura-Ace Di2), but at £12K, let's be honest, that's never going to happen...fatbikephil wrote: ↑Thu Nov 02, 2023 3:30 pm That'll get the 'standards' types foaming at the mouth. A bit heavy as well - 7.5kg plus. The fancy spesh road bike my boss was banging on about the other week is 6.
No mention of price, doubtless in the "if you have to ask, your not in the market" category.....
Just wait and see what kind of saddle bag designs this will trigger. Next to triggering many other things supposedly.firestarter wrote: ↑Tue Nov 07, 2023 5:59 pm It's not April is it ?
https://road.cc/content/tech-news/saddl ... est-304951
I actually really like this, always like skinny tubes on road bikes paired with deep sections.Boab wrote: ↑Thu Nov 02, 2023 2:10 pmOh, you want a bike for rich idiots...? I give you the J.LAVERACK ASTON MARTIN .1R. Featuring "Hidden cables. Hidden bolts.".fatbikephil wrote: ↑Wed Nov 01, 2023 11:15 pm That's slightly perverse - all that tech to make it light and aero but if its got a motor then it will still only do 27kph.
Not sure where you're supposed to put your water bottle...
When looking for a saddle that’s good for the prostate that wasn’t quite what I had in mind.firestarter wrote: ↑Tue Nov 07, 2023 5:59 pm It's not April is it ?
