Post
by redefined_cycles » Thu May 28, 2020 1:27 pm
My Arcteryx have started a slight delamination process and contacted the seller for a repair. They've decided to process a return instead. Don't fancy sending em back as they're, 'oh soooo comfy', and I doubt I'd ever be able to stretch to full price for another set (got em for about £90 I think)..
Anyone got any suggestions on what to use to reattach and stop the delaminating sections getting worse. I have some fabric glue as well as epoxy. Epoxy would probably be too stiff but the fabric glue might not be robust enough as its a tough area to keep stuck together...
Without doubt, best shoes I've ever worn. The delamination might be contributed from excessive cleaning with hardcore wipes...
Post
by Bearbonesnorm » Thu May 28, 2020 2:04 pm
ShooGoo works quite well.
Post
by benp1 » Thu May 28, 2020 2:27 pm
Is that delamination or a split?
ShoeGoo recommendation here, although when I fixed my Timberlands I didn't do a particularly neat job!
Post
by redefined_cycles » Thu May 28, 2020 2:48 pm
benp1 wrote: ↑Thu May 28, 2020 2:27 pm
Nah... delam. Ben... they're ace and amazingly breathable. The grey material must be breathable and it seems to be welded (or cheaper method!) to the black main sections
Post
by Lazarus » Thu May 28, 2020 3:19 pm
another for shoogoo - gives a flexible repair which is essential in a shoe IME
Dean
Post
by Dean » Thu May 28, 2020 8:48 pm
redefined_cycles wrote: ↑Thu May 28, 2020 2:48 pm
The GTX layer is in the sock/bootie (don't know what version you have), so the outer can get damaged and your feet will remain dry. The uppers are all welded, the only glue Arcteryx uses in their shoes attaches the sole to the boot.
