Was wondering what is your preferred bottle material when bikepacking?
I’ve been using the Elite Fly MTB bottles that have the lids and also Klean Kanteen steel bottles.
So been using both but I’m more on the side of using steel. I’m not sure why, I just find drinking from a steel bottle, a more pleasurable experience.
Plastic or Steel?
Re: Plastic or Steel?
Both - but I like that steel bottles tend to keep water cooler for longer and I like that I can stick them on a stove too.
The Swig bottles from Alpkit are the best ive found afyer various Elite, Camelbak, SIS, etc etc. They seem to hold the flavour of the water better. Seems the newer Camelbak bottles are rediculously rubbish and had to throw one or 2 in the bin after just 1 or 2 months of use with mainly (or only) just water usage. Started tasting dirty before ling and maybe they've dropped theyre standards of what materials they use... Possibly built in obsolesence getting better at CB
Whatever standard plastic bidons I happen to have available.
I have a 1L Nalgene narrow mouth, my water filter screws onto the top so easy water collection in the wilds; it fits perfectly in an Alpkit bag on my stem (attached to fork with velcro strap) so no bouncing about. If I drop it when drinking at speed nothing will happen to it. It has been used for so long the measurements on the outside have all worn off.
Metal does keep water cooler on warm days but it dents so easily, I dented a Sigg so badly when I put my rucksack down I made a hole 1cm from the bottom and all the water leaked out.
Metal. I’ve some ancient Sigg bottles with really good covers on the top for keeping the crud off the valve which I like a lot.
Also some newer Klean Kanteen ones. Like Stu I appreciate being able to heat them directly on a fire although i’ve never done that bikepacking - just with my kids in the woods (land owners permission, no trace etc).
I like plastic for "on the go" bottles because I can squeeze it, and they definitely have to have a cap over the nozzle.
Bilbo Baggins.
Bilbo Baggins.
- thenorthwind
I know it's just a plakky bottle Reg, but you've attached it to bicycle, therefore we'd appreciate it if you'd refer to it as a "b'don".* Ta.
* . Please don't.
Edit: I see the swear filter is ahead of me.
