Bargain Alert Thread
- AndyTheBikeGuy
Re: Bargain Alert Thread
Exped stuff available on Sport Pursuit
Cheers, bargain acquiredBorderer wrote: ↑Fri Jan 17, 2020 10:09 pm Ex demo Sonder bikes on sale at Alpkit
https://www.alpkit.com/blogs/news/clear ... jaG4tf5OJA
Apologies to Escape Goat that it kyboshed me buying his
- Escape Goat
Cheeky Monkey wrote: ↑Sat Jan 18, 2020 11:13 amCheers, bargain acquiredBorderer wrote: ↑Fri Jan 17, 2020 10:09 pm Ex demo Sonder bikes on sale at Alpkit
SportPursuit at it again. "Bargain" Marmot togs. Lot of 50%-off stuff. Glad to see it doesn't include Marmot Essence jackets .
https://www.sportpursuit.com/sales/marm ... -nov19?p=2
- BigdummySteve
I think this probably belongs here - I picked up a wire flux mig from Lidl today for those outdoor, upside down and hard to reach jobs and it's surprisingly good. WF mig sometimes gets a bad press but that's mainly because it's not exactly like a normal mig and you need to adjust a few things.
Anyway, if you fancy the idea of a mig welder but don't want the expense of buying gas, I'd recommend one of these - £80 well spent. While you're in, I'd also pick up some spare wire for it - £6 for 2 spools is very cheap and if you're not sure then buy the .9mm stuff.
I don't even have a Mig to weld but I hear old Soviet military stuff is quite cheap these days.
That's good to know stu.
What weight is each reel?
My mig uses both STD and fluxed versions. It is useful for some Jobs. Just have to swap the polarity on mine and away you go!!
Am sure I pay about £9 for 0.45kg from machine mart.
Also bought an inverter arc welder from Lidl to compliment my STD arc welder. I was impressed with its thin metal welding ability!
And it's light to carry.
Don't think I have used my standard arc welder since!
Insanity over vanity
Oh for Pete's sake! Luckily same price as the replacement I bought. Maybe I should get another as a potential replacement replacement.BigdummySteve wrote: ↑Sun Jan 19, 2020 4:31 pm
https://www.sportpursuit.com/catalog/pr ... id/1054243
Is it better than a normal gas less mig mate , been looking around as mine is starting to give up the ghost , not that it welds that great with brewery gas anyhow but boc don’t like their gas bottles in residential premisesBearbonesnorm wrote: ↑Sun Jan 19, 2020 4:53 pm I think this probably belongs here - I picked up a wire flux mig from Lidl today for those outdoor, upside down and hard to reach jobs and it's surprisingly good. WF mig sometimes gets a bad press but that's mainly because it's not exactly like a normal mig and you need to adjust a few things.
- Dave Barter
Mods please delete this before I do something stupidBorderer wrote: ↑Fri Jan 17, 2020 10:09 pm Ex demo Sonder bikes on sale at Alpkit
450g / 104m reels.What weight is each reel?
Better's subjective. It's certainly not better than my big mig set but that was a grand Nice thing about flux core is there's no gas to get blown away(kind of), so it's very handy for those outside jobs. Can be prone to a bit more splatter but if you keep the torch a little further from the work than you normally would it's limited. For owt delicate, there's always a bit of anti-splatter. Ampage will drop right down for thin stuff or up to 140ish for 3mm-4mm plate/angleIs it better than a normal gas less mig mate
Here's one I've just finished.
Cheers stu.
That's £3 per reel saving.
Have you "tested" your new welder?
If so what's it like compared to your pro mig?
I know it won't be as good, obviously,but easy to master?
Took me ages on my Clark one! ( I admit.. I am a pigeon poo king!)
As you say though,windy conditions Working on cars outside,it saves on gas!
That needs doing again, it's leaking everywhere!
I was very surprised how good it was. Nice uniform bead with plenty of pentration. You've only 2 controls - amps and wire speed so very little to mess up.Have you "tested" your new welder?
Nothing gets a welder more excited than "good penetration"!! Fnarr Fnarr!
Just had a browse of Lidl special buys. Looks ok for the price! Will Pop to a store during the week for a physical assessment!
Seeing this about welder I have a question. How difficult is it to learn to weld? I sometimes have a need to weld, generally a small job, and feel it might be worthwhile to be able. Otherwise I have to pay someone or find another way.
Mig is generally considered to be the easiest and in truth the hardest bit is getting the settings sorted - once that's done, anyone should be able to 'join bits of metal together' after half an hours practice. Something like the Lidl welder is about as simple as it gets but can still produce good results.Seeing this about welder I have a question. How difficult is it to learn to weld? I sometimes have a need to weld, generally a small job, and feel it might be worthwhile to be able. Otherwise I have to pay someone or find another way.
Salsa Beargrease alloy frame set £300
https://www.tritoncycles.co.uk/frames-f ... set-p19394
Small Pugs' frame £300
https://www.tritoncycles.co.uk/frames-f ... ame-p17429
garish cork bar tape: https://www.planetx.co.uk/i/q/BTBRCBT/b ... lebar-tape
Cheap Manitou Machete 140mm 29/B+ forks at CRC
https://www.chainreactioncycles.com/man ... 01:38%20AM
Cheap hydraulic brakes still on sale at Wiggle. £12 an end. You will probably want to swap the hoses around. And you will need Tektro barbs/olives if you want to shorten them.
https://www.wiggle.co.uk/tektro-draco-a ... isc-brake/
I've bought and fitted these so happy to give them the thumbs up.
STOP TEMPTING ME!Bearbonesnorm wrote: ↑Mon Jan 20, 2020 6:34 pmMig is generally considered to be the easiest and in truth the hardest bit is getting the settings sorted - once that's done, anyone should be able to 'join bits of metal together' after half an hours practice. Something like the Lidl welder is about as simple as it gets but can still produce good results.Seeing this about welder I have a question. How difficult is it to learn to weld? I sometimes have a need to weld, generally a small job, and feel it might be worthwhile to be able. Otherwise I have to pay someone or find another way.
I'm just about managing to write it off on a basis of having no work space.
That all said, how comparable is it to stick welding? I was okay at that in college but utterly abyssmal at brazing (exploding work pieces a-plenty)
I've got an old set on my Dew, the rotors are cheap and nasty (read: LOUD) but otherwise they have been faultless and played nicely with some spare Avid/Shimano rotors I had lying about. I'd put them on a par with Clarks M.2's.ScotRoutes wrote: ↑Wed Jan 22, 2020 12:46 pm Cheap hydraulic brakes still on sale at Wiggle. £12 an end. You will probably want to swap the hoses around. And you will need Tektro barbs/olives if you want to shorten them.
Other colours available : https://www.wiggle.co.uk/tektro-draco-disc-brake/
