if you were to mark a map with the furthest east, north and western points on the HT550 route, would it be a decent route to do as a tour using road to cut out the roughest and hike a bike sections?
I have done the WHW as a tour, so that is fine, I have done the stuff from bridge of balgie round loch lyon, so that is fine
and the roads up the northern loop look vaguely exciting.
so any advice would be greatly appreciated. and advice on which tracks would be ok on big tyred tourers.
HT550 for a tour ??
Re: HT550 for a tour ??
I did once look at creating a route that stuck as close to the HT550, but went on the road.
This was before the invention of gravel bikes, so road means road.
https://www.strava.com/routes/13580284
I will have a good look at that. thanks very much.
- JoseMcTavish
I love plotting routes! Here's a version that avoids all the toughest pushing bits either with a road or easier offroad alternative keeping the riding at a maximum whilst on a tourer. The only bad thing is you miss out on Ben Alder, Bealach Horn, Ledmore traverse and Fisherfield, which are stunning to travel through but would be hard work without a mountain bike.
https://www.strava.com/routes/24220670
I'd be happy enough doing this on my tourer/gravel/cyclocross/road bike with 40mm ish tyres.
Craig, just looked at your route and the crossing of Loch Loyne presumably is dependent upon very low water levels no?
Normal conditions -
Normal conditions -
- JoseMcTavish
Oh yeah, I had been meaning to say that but got distracted and didn't!
If you do it in September/October you should be good...mostly lovely tarmac either side of the loch too.
Otherwise carry on along Loch Cluanie by main road till you get to the turn off towards Loch Loyne.
Yeah - they draw down the water levels in September each year. Contact the Tomdoun Inn for an update.
I also heard that one of the bridges had collapsed recently (within the past 2-3 years). If the water is very low, it's still possible to do the route.
PICT3460 by Colin Cadden, on Flickr
North Bridge by Colin Cadden, on Flickr
- JoseMcTavish
Think the Tomdoun shut a few years ago, sadly. I'd imagine the Cluanie Inn would have an idea too though.
