The last time I was really active in the Lyn Brainne area (sadly several years ago) the track that runs from Soar-y-Mynydd Chapel to Tyncornel YHA had a massive gully cut into it by water damage. I think the track might have even been officially closed for a while?
Is this still the case or has that been repaired now?
Soar-y-Mynydd Chapel to Tyncornel track
Re: Soar-y-Mynydd Chapel to Tyncornel track
Repaired and open Neil.
Yes, rode it last year and it's back to "normal". All repaired, and if anything a bit looser than before, but fully rideable.
What've you got planned?
I rode it in October in horrible conditions. The track itself was fine!
Thanks all.
Putting together some routes for a multiday DIY gravel/road Audax. Some brevetpacking if you will.
