Does this bike / frame exist
Ti preferred (or nice lightweight Steel)
Sliding / Adjustable Dropouts
67 ish HA
Longish TT (460 ish on a Large)
100mm to 120mm Fork travel allowing suspension or rigid
31.6 seat tube with stealth routing
Genuinely fit a 29x2.6 in it with mud clearance.
Bikes that are close but miss at least one of the requirements, Broken road, nordest britango and sardinha, stanton sherpa, chameleon, travers, cotic, lynskey, etc
Any others?
Ta
ssnowman
Re: Does this bike / frame exist
Post by ssnowman »
I've been on a very similar search, with not quite as an exacting requirement list.
I'm going for the Broken road. It ticks most of the boxes for me.
Another bike that you might want to consider is the Velohold Iron. https://www.veloheld.de/bikesnframes/ad ... oheld-iron available as a frameset or full bike.
May satan walk with you
Be interested to hear back on the Broken Road, I'll take a look a the link too ta.
The broken road can be customised if you ask, might be able to get what you want...?
Scott L
Post by Scott L »
I would be most tempted by getting a Swarf from Adrian up here in the tweed valley. Brilliant bikes, lightweight for steel and can have the geometry customised. Adrian is very knowledgeable and can advise on what you are wanting to achieve.
I have demoed his full sus and it was vaguely exciting!
Hi, Yeah swarf is on the list. I briefly communicated with Adrian last year but I had a broken frame and needed something new quickly.
techno
Post by techno »
faustus wrote: Fri Dec 13, 2019 10:09 am The broken road can be customised if you ask, might be able to get what you want...?
There's a lot of custom sonders popping up on their instagram recently that look lovely.
stooge also do custom options:
http://stoogecycles.co.uk/product/titanium-65029er/
http://stoogecycles.co.uk/product/stoog ... osit-1900/
lune ranger
Post by lune ranger »
Newer Ti Fargo’s will take 29x3.0
Ah, Salsa. I should add to my list. Not a drop bar bike and for Ti... a proper warranty.
Pretty fussy :lol:
wriggles
Post by wriggles »
Why doesnt the Broken Road fit that criteria?
wriggles wrote: Fri Dec 13, 2019 4:11 pm Why doesnt the Broken Road fit that criteria?
Its close, but I thought I'd read somewhere it was designed at a fork length of 470 which seemed a bit short to me. Cant find it now though so that could be nonsense
wriggles
Post by wriggles »
They ship them with 100mm REBA 650b plus which has an A-C of 490 - 500 sagged I guess. I run mine with a 110mm Fox 34 which has an A-C of 525/500 unsagged/sagged. Rides great. Takes 2.6 on an i30 rim as well. Drop @richpips a PM if any questions.
Thats good to know it takes a 29x2.6
Thanks for that :-bd
Ti Timberjack from Salsa if you don't need/want the drops on a Fargo.
trob6
Post by trob6 »
I have a Broken Road albeit with carbon forks and 650b plus wheelset with 2.8 tyres and the clearance is big , when you get to that sticky mud it will fill any gap anyway.
I also have a custom build steel hardtail by my friend Chris Yeomans of Smithyframeworks he will make you anything you want.
imo a good length to design to for a 100mm fork -the Ramin was also anyway- it won't rule out a 120mm if the STA and BB drop range is steeper + lower to start with (as most newer geometries are)
29" Reba? RS 29er forks and B+ are the same, a 100mm Reba is 506mm A-C, so ride height / active sag ~35mm less = ~470mm. Bingo. ( :ugeek: have the SRAM tech site on the bookmarks list)
