Which GPS?
Chew
Which GPS?
Post by Chew »
Thinking of getting a GPS system (BB200 in mind) and interested in what other people use.
Looking for OS mapping
Reasonable cost/size/functions
Battery life
valleydaddy
Re: Which GPS?
Post by valleydaddy »
well I recently got a second Adventurer 2800
http://www.memory-map.co.uk/adventurerg ... r2800.html
I am still trying to get to grips with it, to be honest I haven't tried that hard.
I need to get it sorted I think.
For the WRT Steve used a Garmin unit just to pull up the grid reference to check where we were on occasions it wasn't totally clear to us.
Chew
Re: Which GPS?
Post by Chew »
Heard some poor reviews of the Memory Map. Like the Garman, but dont think you can change the battery, so it rules out use for multi day rides
valleydaddy
Re: Which GPS?
yes you are right but you can get a battery pack for the MM but I wouldn't have it on like a satnav really as thats no fun.
I did see one guy at the WRT with a mini solar panel on his bags to top up his GPS so you could look into that idea too ;)
Taylor
Re: Which GPS?
Post by Taylor »
Garmin Oregon works by AA batteries.
The Dakota also works on AA's I believe.
Both have 1:50000 base maps on.
For multi day they're both ideal.
I have the Oregon fwiw.
Bigface0_0
Re: Which GPS?
Post by Bigface0_0 »
I've got an edge 705 which will give you grid reference and a basic map and for multi days I've got a power monkey for charging gps and my phone which has full memory maps on if needed
BIKE RACING IS LIKE HAVING A MULLET, BUSINESS UP THE FRONT, PARTY IN THE BACK…!!!
didnothingfatal
Re: Which GPS?
Post by didnothingfatal »
I have a Garmin GPS60, and a old GPS Foretrex 101. Wouldn't buy a GPS unit that requires charging, no good for extended trips. This has been reinforced by my Forerunner 405, using it's battery up in 7 hours. Wouldn't bother with maps either, plot routes on MM or online and then transfer route to GPS, the more gizmo's the shorter the battery life. I do think the proximity alert feature for waypoints is a great feature for riding though.
Chew
Re: Which GPS?
Post by Chew »
Liking both the Garmin Oregon and Dakota.
Any real difference?
Screens bigger on the Oregon it uses more power, and its a tad more expensive. Apart from that they seem identical?
