Question to the collective wisdom.... attaching bottle cages to a set of RockShox suspension forks so will need to order the correct size... so question(s)..
What is the size of jubilee clips did you go for and was it OK?
or
How does one measure to work out which size is require without going too big (small)...?
Thanks.
Jubilee clips sizing
- NorwayCalling
Re: Jubilee clips sizing
They're usually sized by diameter on a 'from' 'to' scale Mike eg 18mm to 26mm.
remember to factor in that you will be using something under them - rubber or some such that will increase the circumference -
40 mm for example range is 40-55
next is 30-40
I am sure there are others but stanchions will be 32 or 36 so tubes going to be 40-50 at a guess
next is 30-40
- NorwayCalling
