SPD / flat pedal
ootini
SPD / flat pedal
Post by ootini » Thu Aug 01, 2019 2:23 pm
Anyone have recommendations for sided pedals? One side SPD the other side flat.
Re: SPD / flat pedal
Post by benp1 » Thu Aug 01, 2019 2:31 pm
I've had both the Shimano options. One is shaped more like a flat pedal, like an rectangle with a rounded profile to the two outer corners. The other is more oval shaped. In fact I'd had two of these, one silver and one black
Oval shaped is a nicer pedal if you spend more time in SPDs, rectangular one is better if you'll use the flat side equally as much
I've done thousands of miles on mine and they're excellent low maintenance items, they get ridden through all winter
Mike
Post by Mike » Thu Aug 01, 2019 2:50 pm
Ah ive just sold a pair of shimano double sided metal pedals to a friend, they are around 32 quid on net. flat one side cleated the other.
Post by Alpinum » Thu Aug 01, 2019 2:54 pm
Funn Mamba. SPD with release force adjustment and suitable for cleat shoes with deep lugs.
The other side features a really good flat pedal. Really like them for some instances, where I want a bit of both worlds
Charliecres
Post by Charliecres » Thu Aug 01, 2019 6:11 pm
I’ve got some Shimano one-sided spds (sod one side, rounded useless surface on the other) which I think are marketed as ‘touring’ pedals. Don’t buy them*, they have zero advantages over an ordinary spd, except they look a bit more ‘road’.
*I realise you weren’t about to. :smile:
Post by benp1 » Thu Aug 01, 2019 9:05 pm
Those are the ones I like!
Spd side is good and the flat side keys me ride in normal shoes of I have an errand to run at lunchtime or similar. But spd side is used 95% of the time. Dues to the weight balance they also stay the right way up when I stop so reattaching is a piece of cake
Specialist Hoprocker
Post by Specialist Hoprocker » Thu Aug 01, 2019 9:31 pm
I've got a couple of pairs of these:
https://www.wiggle.co.uk/shimano-a530-s ... ng-pedals/
I could be persuaded to sell a pair if you want :-) I find them pretty good. The set that is in use is on my do anything, go anywhere semi fat 27.5/29er+ singlespeed rigid. Which doubles as the pub bike, hence the flat side!
Drop me a message if you want them.
dlovett
Post by dlovett » Thu Aug 01, 2019 10:11 pm
Love Mud Jeckels. So good I bought another pair. You can remove the studs on the no spd side as well if you like skin on your shins.
Charliecres
Post by Charliecres » Fri Aug 02, 2019 9:40 am
I can’t believe we’re talking about the same thing ben
Mine are like this - https://www.wiggle.co.uk/shimano-pd-es600-spd-pedals/
Designed to be single-sided (for no good reason I can fathom.
Post by benp1 » Fri Aug 02, 2019 11:13 am
You are indeed correct, we're talking about different things!
I've just the A530 and M324 pedals from Shimano. The latter was on a bike that got nicked. the former is on my commuter and has survived thousands of miles and is ridden in all conditions. They've been great considering how cheap they are. Latter are better for riding on the flat pedal bit though, A530 can be a bit slippy
Post by Specialist Hoprocker » Fri Aug 02, 2019 9:06 pm
Andiphim
Post by Andiphim » Fri Aug 02, 2019 10:22 pm
Alpkit love mud Jeckles are my choice if I need to have both options.
Seem well made and the usual Alpkit sensible pricing.
ootini
Post by ootini » Sat Aug 03, 2019 12:04 am
Could be interested. How much wear / miles have they seen ? Thanks
