Uses the phrase 'long distance mountain biker' but still.....
https://www.theguardian.com/us-news/201 ... igh-desert
Bikepacker saves a life
Re: Bikepacker saves a life
Cool story!
Good stuff
The "safety" devices like phone, avalanche beacon, GPS Messenger, PLB aren't just for "us" as this case shows...
Thats a happy ending. Thanks for sharing Gairy.
"6 hours to go find a cell signal at nearest campsite" had it not been for his tracker. Makes you wanna go buy an InReach...
- thenorthwind
Brillianrt story.
Also, the picture looks like one of my typical bivvies
- In Reverse
Well done that man.
Managed to get a decent pic of the near-dead bloke for Strava too
A fuller version here - https://bikepacking.com/plog/man-found- ... he-desert/
was an interesting readwhitestone wrote: ↑Sun Aug 04, 2019 8:34 am A fuller version here - https://bikepacking.com/plog/man-found- ... he-desert/
also a good reason for two way commuication
could have let partner know was okay and assisting another
similarly could have let the emergency services know the nature of the problem
Yes, it's one of my (very)slight concerns about pressing the SOS button on my SPOT if I came across someone in a similar situation. There'd be an hour or two of panic outside the bubble. Giving the emergency services a heads up is very much a positive. Note that I wouldn't hesitate to press the button, I've an emergency notification/locator device, there's an emergency so ...Asposium wrote: ↑Sun Aug 04, 2019 4:39 pmwas an interesting readwhitestone wrote: ↑Sun Aug 04, 2019 8:34 am A fuller version here - https://bikepacking.com/plog/man-found- ... he-desert/
also a good reason for two way communication
A counter argument is that this story made the news precisely because it's so rare a situation and thus a novelty to the news channels.
I think the guy was very lucky, he could have collapsed a few metres from the track and would never have been seen in that brush. When I worked in the desert (Oman) it was continually stressed on us that if your vehicle got stuck/broke down you stayed with it - far easier to spot a truck in an air search than you waving your arms around.
