Breakfast stove.
Breakfast stove.
Post by Bearbonesnorm » Thu Jul 11, 2019 9:07 pm
I'll often survive on 'not much' when I'm out but recently the thought of starting the day with a nice bacon butty has become quite appealing. Obviously my usual 8g stove wouldn't be up to the task of frying bacon, yet I just couldn't bring myself to go down the gas route - instead, I made a giant version of the 8g stove.
Weighs 45g and has a burn time of up to 20 minutes, so more than capable of a bit of frying work :wink:
#corporate shill for hire
middleagedmadness
Re: Breakfast stove.
Post by middleagedmadness » Fri Jul 12, 2019 6:57 am
But still use my trusty trangia burner if it's me and the boy,( which in turn means having to cook a proper breakfast , probably 4x heavier than that stove though)
Post by ScotRoutes » Fri Jul 12, 2019 8:40 am
Question: what weight/volume of meths would be required?
RobLyon
Post by RobLyon » Fri Jul 12, 2019 9:34 am
What's happened to your after burner stove and how does this compare?
Post by Bearbonesnorm » Fri Jul 12, 2019 9:55 am
I'm struggling to source the inners. My supplier tells me they will be back but they can't say when.
Being a side burner and having the pan sit directly on top of the stove means this suits a frying pan very well. The AB has a more concentrated flame and needs the pan to sit above the stove ... not easy to make a neat solution to that for a frying pan.
About 40ml - 50ml to get 20 minutes Colin.
Post by whitestone » Fri Jul 12, 2019 10:02 am
Looks to be similar size to a beer/pop can stove unless your hands are particularly big or small :wink:
Post by Bearbonesnorm » Fri Jul 12, 2019 10:22 am
68mm OD and 55mm high Bob. I could reduce the height a bit without reducing capacity but it's just how it worked out. Nice thing when compared to a pop can stove is you can actually stand on these ..... not saying you'd want to but it does show that they're quite robust :wink:
Post by whitestone » Fri Jul 12, 2019 10:27 am
Did you ever do the schoolkid trick of standing one-legged on an empty pop can then tapping the side so it collapsed under you?
Post by benp1 » Fri Jul 12, 2019 1:53 pm
Thanks for that Bob, sounds like a good plan for some weekend fun with the kids!
Just need to buy and drink some cans now
Post by whitestone » Fri Jul 12, 2019 3:12 pm
We used to just tap the can with a finger but a pencil will be a bit safer. :o Also wear decent shoes/boots with solid soles :wink:
Post by Zippy » Mon Jul 15, 2019 5:05 pm
That is definitely a past time of mine :lol:
dlovett
Post by dlovett » Tue Aug 13, 2019 11:48 am
Down Saff, we call that flat packing. I needs to be a cheap lager can and several attempts need to be made.
It's also good for the environment too, as more cans can fit in a recycling box when flat packed.
