- ledburner
I bought a Pedros Chain pig (recommend it ) , so I cleaned my road bike. Cleaned/degrease / lubed chain.
[It has been oiled & wiped down. The original grease was stiffening up. It only be used for good weather and it is probably the 2 proper clean in 5 years!] The rear derailleur pulleys were also replaced. Now it runs sweet . The degreaser was bought in the 90's!
I also rebuilt the rohloff chain tensioner on my cube 29er9. It is a very early edition tensioner, from early 1999 so the bottom pulley had a 4mm bore not the usual 6.35mm bore. Rohloff own spec, those pulleys are obsolete , I had to use modern 10T bearing pulley, (getting less available ) . Since I couldn't source a suitable spacer make a spacer for the bearing to sit on. 6.35mm Dia, x 9mm, 4m bore . The chain was also cleaned and lubed.
An Interesting day. Faff, fiddle & fun... Hmm.
I'm running out of excuse not to get up those hills!
Fixed the latest in my current series of punctures, thanks to hedge cutting, and fitted some nobbly tyres.
Made another hole. This time into the posh (second owner me so wasn't as posh by the time it arrived) steel frame.
Finally got round to attaching the seat stay light and recharged all my other lights only to discover that the only front light have that's working is my Joystick - both the FWE 500 and my old candbeseen are dead as a dodo even after an overnight charge, joy.
Can't wait... We have 73 chevrons to get through. Tel me when. Bring your baggies
Fitted a new 11 speed chain to my fat bike after throwing the previous (nearly new) one and bending it on a ride yesterday.
I transplanted some SKS mudguards from one gravel bike to a new version of the same bike (outside in the rain), which as everyone who has put SKS mudguards onto a bike knows took two hours and eliminated any motivation to ride the thing.
stripped it down. placed it in several boxes, and sent it out via various couriers to various location throughout the UK.
hope everyone is well pleased with their purchase..................
When you gonna spill the beans as to what's coming as the replacement. Proper interested but didnt wanna prod it out of you when I came and picked that 'funny' saddle. Thanks again Tony...
Broke it.
Again.
Sticking free hub, worn rear bearings and an odd tendency for the rear cable disc brake to lock on fully (despite a change of cable, outer, caliper and pads).
And it's always the MTB that fails: the "skip bike" just seems to plod on like the Top Gear Toyota Hilux .
https://m.youtube.com/watch?v=xnWKz7Cthkk
Again.
Regards the cables Pete... Have you checked the oritentation and grade of bend of the cable from the levers to the calipers. I recall some BB7 I had on my brothers bike, used to always chew up the ferrule/end of outer at the lever end. You have too much pulling powerMuddyPete wrote: ↑Sat Dec 26, 2020 1:23 pm Broke it.
Again.
Shaf - thanks, but nope. The moving pad moves back and forward easily: it's as if the disc is sticking to the static pad. It's happened with 2 pairs of pads and after a caliper renewal, too. Something to do with the pad-disc interface, perhaps .
Interesting. What brakes? I'll remember to stay away Hope you get summat sorted...
You might want to fit a saddle unless you're planning some standing only climbs........redefined_cycles wrote: ↑Mon Dec 21, 2020 5:52 pmCan't wait... We have 73 chevrons to get through. Tel me when. Bring your baggies
Finally got time to fit the sks velo mudguards to my Arkose. That was an interesting experience, lots of frustration trying to squeeze metal nuts into plastic fittings until I discovered that a 10 mm Alan key makes a good press.
They’re made from a really stiff plastic so they’d probably be ok without the optional stay kit but fitted it anyway. The rear went on ok though due to the stiffness there’s a bigger gap between the tyre and get mudguard in places than I’d like. The front went really smoothly until I discovered that the longest supplied fork bolt wasn’t long enough to get all the way through the fork so I need find a longer one from somewhere.
I have cut several tiny slits in the sides with a dremel and fitted a spacer to the seatstay bridge to let the mudguard sit nearer to the tyre, I have not found that the slits allow any spray to get me dirty or have weakened the structure overall (I am using the stay kit).PaulB2 wrote: ↑Sat Jan 02, 2021 10:27 pm Finally got time to fit the sks velo mudguards to my Arkose. That was an interesting experience, lots of frustration trying to squeeze metal nuts into plastic fittings until I discovered that a 10 mm Alan key makes a good press.
Saddle sorted Stevenslarge wrote: ↑Sun Dec 27, 2020 9:32 pmYou might want to fit a saddle unless you're planning some standing only climbs........redefined_cycles wrote: ↑Mon Dec 21, 2020 5:52 pmCan't wait... We have 73 chevrons to get through. Tel me when. Bring your baggies
Put the gears back on the fat bike.
I'd used a normal cog (rather than a specific wide footed SS cog) at the back and it had really dug into the freehub splines, an Industry Nine hub, far more so than the supposedly "soft" Hope freehubs. Maybe I'm just AWZUM
With it all stripped down I noticed play in the bottom bracket so will need a new one of those. It was only a cheap Deore and has been on the bike for four years so not bad for £11.
Then a quick ride in the snow to check the indexing was OK We've something like 6-8cm here, it's all a bit wet but it's meant to freeze overnight so I'll get out in the morning for a ride.
- ledburner
Pssst,
Well done but don't mention that word.
Finished something I started last March.
I had to take a hacksaw and file to a set of XTR cranks so that I could fit a Trickstuff Exzentriker BB. As a result, I've been able to remove the chain tensioner I'd fitted and the bike looks much "cleaner" now.
- ledburner
Are these for threaded or press fit bb bearings?ScotRoutes wrote: ↑Fri Jan 22, 2021 6:09 pm Finished something I started last March.
I suppose they effect the chain line?
Edit: I've just seen the price 'Oooh, Missus! That'll use all mi' coupons! '
I got it secondhand for much cheapness last year.ledburner wrote: ↑Sat Jan 23, 2021 1:21 amAre these for threaded or press fit bb bearings?ScotRoutes wrote: ↑Fri Jan 22, 2021 6:09 pm Finished something I started last March.
Put a venturemax XL bar on it... Wrapped it in outrageously expensive 40mmx5mm thick tape.
Swapped a 0 degree stem for a 6 degree.
I'm sure it will feel super duper.
Might bleed the brakes before I ride it though, as they're don't work currently
- ledburner
Lucky is you!ScotRoutes wrote: ↑Sat Jan 23, 2021 1:53 amI got it secondhand for much cheapness last year.ledburner wrote: ↑Sat Jan 23, 2021 1:21 amAre these for threaded or press fit bb bearings?ScotRoutes wrote: ↑Fri Jan 22, 2021 6:09 pm Finished something I started last March.
