Can't post a photo as I'm a long way from home but I've got an OnOne Scandal with track dropouts and a White Industries Duo 2 speed freewheel. I've married this to a double chainset so can manually change from 34/19 to 36/17 without moving the wheel or needing a chain tensioner. Doesn't sound much difference in ratios but it is surprisingly different.
Me and a mate have been thinking of trying that using a surly dingle. I do need to bite the bullet and give it a go sometime. Being picky I wish the dingles or the WI duo cogs had a bigger teeth gap to allow a wider ratio gap.
(Some smartarse is going to come along and suggest we fit a cluster of sprockets on the rear wheel along with a lever / pully arrangement to enable constant chain tension whilst allowing the chain to move across the different sprockets....)
Mostly finished building my Transition Rapture CX into a long distance brevet/audax/all-road machine.
This is the bike that has the Cam-ano gears. Campy Centaur 10sp with a Shimano GRX crankset to take advantage of 30/46 chainrings. Seems to shift as well as with the proper chainset in the work stand.
Dingle speed wise, have you tried 2 cogs on a hg freehub body? Planning on setting mine up like that, probably 30-18 and 33-15 on 650b wheel
Thats what we were thinking so be interested to see how you get on.
Steamroller now complete apart from mudguards. I have them it's just that it looks so nice without them in my living room....
Cath's rear mech was, shall we say, sticky. When in the higher gears the jockey arm wouldn't move back to pick up the slack.
Cue me removing the mech, cleaning, greasing and reassembling it. Never done one before so it took a while and a couple of YT videos. Annoyingly the bolt that holds the arm is meant to be done up to 8Nm but at that torque it hardly moves so I had to loosen it off a touch to allow it to work.
Raked through the potting shed and raided the spare parts box. I now have the following that can be fitted to the Scandal:
- Calibre Trail 70mm stem
- On-One OG Handlebars
- Tektro Auriga brake levers
- Tektro Novela mechanical disc brakes
- Shimano Altus shifter
- Shimano Alivo 8 speed rear dérailleur
- Shimano 8 speed cassette (if I can get it off the old fat bike rear wheel)
- 2x 160mm disc rotors
- On-One Twelfty MTB Seat post
- Shimano PD-M324 SPD pedals
Well done Bob. I'm currently away from the bike (knee injury but not sure if the extreme lower back pain is me staying away from the cycling or it's gonna make it worse!) but the only real things needing doing on the bikes are...Boab wrote: ↑Tue Jan 25, 2022 2:15 pm Raked through the potting shed and raided the spare parts box. I now have the following that can be fitted to the Scandal:Pretty much all off the old Dune fat bike.
Mtb: sway out calipers and rebleed then good to go!
Road: swap the chain set to the semi compact power meter thingy.
Really need to motivate self to get it done and get back out there
This has been running very well over 600km or so.lune ranger wrote: ↑Tue Dec 28, 2021 1:10 am Mostly finished building my Transition Rapture CX into a long distance brevet/audax/all-road machine.
The gearing range isn’t quite what I need though. It’s fine with fresh legs or unloaded on the road but less good off road, loaded or tired. I need something easier than 30x29 if I’m to use this bike for the very long distance multi surface rides I’d like to do.
Sooo…
I just fitted a SRAM 10 speed cassette and medium cage rear mech. Getting this to play with Campy shifters has required a Jtek ShiftMate and a Wolf Tooth Road link (thanks FLV).
I now have a properly Frankenstein drivetrain with components from all of the big 3. All I can say is that it works almost perfectly in the workstand - what remains to be seen is if it works in the real world.
Will it hold up or will I be looking for SRAM shifters in a month or so? On the bright side if I do switch shifters I’ll have all the original Campy back with which to build back the Ribble it came off
Stay tuned for the next instalment.
Shimano, campag and SRAM. Nice one Luke bet it looks very posh
Bit of adogs dinner really… but if it works then that’s what counts.redefined_cycles wrote: ↑Sat Feb 05, 2022 12:28 pm Shimano, campag and SRAM. Nice one Luke bet it looks very posh
- ledburner
Best ofAll* or Beast of all?lune ranger wrote: ↑Sat Feb 05, 2022 12:54 pmBit of adogs dinner really… but if it works then that’s what counts.redefined_cycles wrote: ↑Sat Feb 05, 2022 12:28 pm Shimano, campag and SRAM. Nice one Luke bet it looks very posh
Its Shi(t) mano Tourney of course, all eBay sellers rate em
seriously I.. *hope it works for you
So do I. Shifters are hellishly expensive, even second hand.
Finally wrestled the mudguards onto the steamroller. Turned into a right marathon for various reasons but I can now ride it in the rain without getting water sprayed up my backside and into my face / groin / legs / belly etc. Doesn't look quite as sporty as it did but I may take them off again if we get some dry weather this year.
- TheBrownDog
This morning I gave it a proper wash after a mud fest ride yesterday and set to indexing the SRAM GX 1x12 which was shitting me all day. Ghost shifts all over the place which made the techie stuff extra exciting.
I just can't get it right. Either it shifts nice going up the cassette, but won't shift down. Or the other way around.
I've never had anything like the issues I've got with this groupo. Rear derailleur alignment is spot on.
The Hive will know. What's the process?
That's usually a sign of a sticking cable.... give a clean or renew?TheBrownDog wrote: ↑Sun Feb 06, 2022 1:53 pm This morning I gave it a proper wash after a mud fest ride yesterday and set to indexing the SRAM GX 1x12 which was shitting me all day. Ghost shifts all over the place which made the techie stuff extra exciting.
- JohnClimber
Absolutely nothing.
But the double garage were they live now has a floor and is not covered in stuff I've dumped there.
I didn't realise I had so much floor and workbench space.
Still got the bike packing and packrafting shelving to sort out, but now I have the room this wiil be a nice evening job.
Now the challenge is to try and keep it that tidy without it becoming a dumping ground yet again
Absolutely nothing.
My garage is pretty good in terms of being tidy as the bikes are kept there but the loft…
Getting pedal strikes on the Pinnacle Ramin 3+. In 650b guide. Took it for a ride today and was meant to come back and change the angle of the eccentric BB but haven't got round to it.
Current position of the BB inside the eccentric is at about 9 o clock. Am thinking if I put it at 12 o clock I should alleviate the pedals strikes (only off camber) but also not messing up the chain length too much
Watch this space!
Watch this space!
- ledburner
post a picture!redefined_cycles wrote: ↑Sun Feb 06, 2022 8:26 pm Getting pedal strikes on the Pinnacle Ramin 3+. In 650b guide. Took it for a ride today and was meant to come back and change the angle of the eccentric BB but haven't got round to it.
Watch this space!
Or fit shorter cranks if that's an option, Eg going from 175mn to 170mm. Ivm just throwing more ideas on the pot...
Thanks Dan. Will try and post a pic. Going to smaller cranks is probably not an option as it's more moneyledburner wrote: ↑Sun Feb 06, 2022 9:38 pmpost a picture!redefined_cycles wrote: ↑Sun Feb 06, 2022 8:26 pm Getting pedal strikes on the Pinnacle Ramin 3+. In 650b guide. Took it for a ride today and was meant to come back and change the angle of the eccentric BB but haven't got round to it.
Watch this space!
When we gonna go for out yearly mtb ride mate?
- ledburner
err, when I've got some lard off..redefined_cycles wrote: ↑Sun Feb 06, 2022 9:43 pmThanks Dan. Will try and post a pic. Going to smaller cranks is probably not an option as it's more moneyledburner wrote: ↑Sun Feb 06, 2022 9:38 pmpost a picture!redefined_cycles wrote: ↑Sun Feb 06, 2022 8:26 pm Getting pedal strikes on the Pinnacle Ramin 3+. In 650b guide. Took it for a ride today and was meant to come back and change the angle of the eccentric BB but haven't got round to it.
Watch this space!
cranks you've sold all your spare parts bin off then....
No Dan... the shed and outhouse are a bit of a mess. Need a good clear out and then some more shelves putting up with some better organisation mate. You don't need lard-off to go for a simple mtb ride mate
- ledburner
Re: What you done t' your bike today- Rim Tape woes
I just taken off the back tyre as it wasn't holding air compared to same tyre on front. . The rim taping was looking suspect so I stripped it off and notice all the spoke holes has solid sealant in under the RimTape. one tape had properly failed/ been bodged on One Spoke hole so was all sealant probably also causing the sealant in the rim cavity.redefined_cycles wrote: ↑Sun Feb 06, 2022 11:20 pm No Dan... the shed and outhouse are a bit of a mess. Need a good clear out and then some more shelves putting up with some better organisation mate. You don't need lard-off to go for a simple mtb ride mate
I cleaned it up as best I can. Then dried off the trapped moisture. I noted some sealant was gooey, Maybe from the trapped moisture? The Bond of sealant between rim & tyre wasn't great as well. re-tape tomorrow. morning.
Any Advice ? ??
Sounds like you have a right good job of cleaning on your hands.
