Bag bag spacers
Bag bag spacers
Has anyone found, or bodged, anything to space a bag away from the bars a little?
It's not actually for bikepacking it's just to space the handlebar bag off a little on my road bike, one of these https://roadrunnerbags.us/collections/b ... le-bar-bag
15mm ish would do it, straps are 25mm wide
Re: Bag bag spacers
Revelate make spacers: https://www.revelatedesigns.com/index.c ... and-Repair
I'm sure it would be fairly easy to find some dense foam and make your own.
Re: Bag bag spacers
Couple of short lengths of pipe lagging? The 15mm stuff will slip over the bars snugly.
Re: Bag bag spacers
Two small pieces of plastic pipe of 25mm internal diameter. Feed the straps through in both directions so that you form a figure of eight with your bag as one loop and your bars as the other and the pipe as the crossover point.
Re: Bag bag spacers
I think Dr Jon has made some with a 3d printer. Same guy that made the stem cell and top tube bag strap attachment widget things
Re: Bag bag spacers
Strangely enough, I was contemplating laser cutting some of these this week, just trying to decide on the material. If I sort it, I'll post on here and could probably send some to you
Re: Bag bag spacers
Thanks for the suggestions, I should of been clearer this is for my vintage road bike so I want it to look pretty:)
Paule that would be Great if you do
Re: Bag bag spacers
Surely you'll be wanting leather then?I should of been clearer this is for my vintage road bike so I want it to look pretty:)
Re: Bag bag spacers
I'm vegan
It's not all period correct, enough wrong to upset purists
Re: Bag bag spacers
Forgot about that - wood then?I'm vegan
Re: Bag bag spacers
That might just work!Bearbonesnorm wrote:Forgot about that - wood then?I'm vegan
Re: Bag bag spacers
Layers of 3mm plywood, with neoprene on the outside, was my most likely choice at the moment.restlessshawn wrote:That might just work!Bearbonesnorm wrote:Forgot about that - wood then?I'm vegan
Re: Bag bag spacers
Pretty much done this in the end except with some rectangular plastic with a 25x10 opening in, looks quite neat I think and gives the bag enough space to clear the gear cable and the stem bolt. CheersScotRoutes wrote:Two small pieces of plastic pipe of 25mm internal diameter. Feed the straps through in both directions so that you form a figure of eight with your bag as one loop and your bars as the other and the pipe as the crossover point.
IMG_3424 by Shawn McFarlane, on Flickr
IMG_3426 by Shawn McFarlane, on Flickr
Re: Bag bag spacers
Looks very neat.
Re: Bag bag spacers
Thanks for the idea :)
Re: Bag bag spacers
That looks significantly nicer and lighter than my laser cut idea... I think I'll go for the simple plan too! Thanks for the inspiration
Re: Bag bag spacers
What I used are actually keepers for thick webbing straps , they were a bit wider so I trimmed them down a little to sit the bag just where I wanted. I can send you some foc if you want as I have a small bag full?PaulE wrote:That looks significantly nicer and lighter than my laser cut idea... I think I'll go for the simple plan too! Thanks for the inspiration
Re: Bag bag spacers
They look very similar to the spacer blocks on tree straps, something I've used many a time but never thought 'outside the box' for that as an alternative use! Joined up thinking, eh
- thenorthwind
Re: Bag bag spacers
Last time I got some bits from Planet X, I added a couple of these to the order: https://www.planetx.co.uk/i/q/TOBYFH/nr ... ame-holder
They're supposed to be for a specific C02 setup, but they're just a shaped rubber block and a strap. I got them for holding a D-lock when I go to the pub on a bike without the usual mount, but I've also used them to hold tubes and could no doubt be used for other stuff.
The blocks have two slots for a 25mm (I think) strap, so could be used as spacers for bar bags.
I think they were only 99p when I got them, but in true Planet X fashion, they're now £2.99. And you have to order from PX
Re: Bag bag spacers
guys - Andy at backcountry has a big box of Bill and Ted spacers but don't think he has them up on the shop yet. 2 sizes, fire him a message if you are keen!
these are the bigger ones for 25-30mm webbing.
Re: Bag bag spacers
Yeah they would have been ideal if he could be bothered answering people so now I won’t buy the other thing I was going to get from his shop either
I’ve had better luck writing to Santa ... actually I’ve had better response from PlanetX
- thenorthwind
Re: Bag bag spacers
Interesting Shawn... I had some money from family to spend on a packrafting course with him this summer, but he's stopped replying to my emails about that too, so may well not see that either
Re: Bag bag spacers
sorry to hear that guys - ill drop him a message in case his email is weirded out - facebook or instagram DM works well!
Re: Bag bag spacers
This is not how businesses run imhodrjon wrote:facebook or instagram DM works well!
I asked him about specs and prices, after 3 days he replied with "Yes, I will check. cheers Andy"
that was 14 days ago
I was considering a strap deck but now I'm only buying one if I can get it straight from you
