The price of tools.
The price of tools.
I visit bothies quite a bit and it seems that many have saws supplied but not axes which are often more suitable for cutting wood so thought I'd see what hand axes were available and how much they weigh.
I was a bit surprised at the cost of some
https://www.knivesandtools.co.uk/en/pt/ ... sheath.htm
This was more what I had in mind.
https://www.knivesandtools.co.uk/en/pt/ ... re-axe.htm
Re: The price of tools.
Ray, just nip down to your local hardware store and see how they handle. The ones you've linked to don't have enough "heft" to split logs - well you can use them but you are using your strength rather than the momentum of the axe to do the work. That size is more for chopping kindling.
Very few seem to be properly sharpened purchase either.
I recently bought an ace this size as a gift. Went for a small silver line from toolstation for a tenner.
A few passes on the bench grinder then whetstone and it’s kitchen knife sharp now!
they are like bikes in that you can get one for pence or fr thousands.
Main thing is how often will you use. - the greater the use the higher the quality. IME anything basic will chop straight dry wood and i use one form aldi as it is never going to have a hard life - I have a hydraulic log splitter so its main use is kindling.
I would not want to take it on a bike ride with me mind.
What about a wedge and then just bashing the floor/using a rock?
Thinking of wight and TLS there,
https://www.axminster.co.uk/bahco-split ... dge-101036
My son has a Gerber version of the bottom axe Ray, it doesn't hold an edge well
But will do 'small ' campsite' duties, I have an ex firemans hand axe and a cheap Stanley
One I don't mind bludgeoning with a rock , however, for not much more money
Than the Fiskars one have a look at the Hultafors small trekking axe, I have the slightly
Longer version and it's a lovely piece of kit, sharpens well and holds an edge for ages,
They have enough bant to split logs etc....a cracking piece of Swedish steel. I use mine a
Few times a week in conjunction with a Husqvarna chainsaw as I have just put a log burner
In and splitting and making feathers etc is a regular occurrence
All good advice, thanks. Wether I'll actually go and purchase one is doubtful due to weight. As mentioned you need something with a bit of heft to split logs. The wedge sounds like a good compromise though.
If you want a really good axe get a gransfors bruks - they are pricy but they are hand made by a Norwegian dude who signs your axe. They are top quality, can hold a razor sharp edge and will last for ever (with occasional replacement of the head and the haft of course )
There forest axe will cut through wood up to 8" dia and works as a reasonable splitting axe. The wildlife hatchet is great for kindling and slicing up smaller stuff (as well as slicing all the tendons in your thumb if you aren't careful...)
[url][/https://www.gransforsbruk.com/en/produc ... st-axe/url]
Maybe I shouldn't go playing with axes after all. I've just made a basic rookie mistake with my very sharp penknife. Used it for something I shouldn't be using it for and it folded up on me inflicting a rather nasty cut, doh! .
Gransfors are Swedish.
They are also very expensive. They are beautiful handmade items and I have one myself.
I can recommend either Helko Werk (German) or Prandi (Italy) as really good alternatives. Not hand made but hand finished. The edges are hand ground and the overall quality is great.
I'd probably never want to carry an axe bikepacking unless it was fat biking in a winter boreal forest with Lars Falt.
You are looking at a combined head/shaft weight of at least 600g and length of 40cm minimum to start being useful for splitting in a meaningful way.
600g I can cope with, .lune ranger wrote: You are looking at a combined head/shaft weight of at least 600g and length of 40cm minimum to start being useful for splitting in a meaningful way.
I have a gransfors ace too! A 30th birthday present, it’s had 12 years of hard work, been sharpened once in that time and is still spot on.htrider wrote:If you want a really good axe get a gransfors bruks - they are pricy but they are hand made by a Norwegian dude who signs your axe. They are top quality, can hold a razor sharp edge and will last for ever (with occasional replacement of the head and the haft of course )
Not cheap but it’s looking like it will our live me!
Were the other 8 years easy?A 30th birthday present, it’s had 12 years of hard work, been sharpened once in that time and is still spot on.
Bearbonesnorm wrote:Were the other 8 years easy?A 30th birthday present, it’s had 12 years of hard work, been sharpened once in that time and is still spot on.
Ooof! Harsh.
Stuart, I can see some justification in those Clint-sticks now!
A good bow saw is much better than an axe for cutting firewood for use in bothies, and a sawhorse makes it even easier.Ray Young wrote:I visit bothies quite a bit and it seems that many have saws supplied but not axes which are often more suitable for cutting wood......
That's going to depend entirely on the diameter of the source wood you have to hand. If it's sticks and branches, then maybe yes.ripio wrote:A good bow saw is much better than an axe for cutting firewood for use in bothies, and a sawhorse makes it even easier.
Realistically to process wood efficiently you need both a saw and an axe - 'salt & pepper'.
Not all bothies have saw horses or good quality bow saws though. Add in wet wood and a saw can be a right pain.
I have two gransfors axes, I had a third (the mini one) but sold it on ages ago. One of my previous hobbies, which I suppose is still an interest, was bushcraft. I also have a Gerber back paxe somewhere
Knife collecting was also a hobby and I still have my collection, some of them pretty pricey and/or custom. Rarely use any of them now, mainly just the Swiss Army Knives, which are probably the cheapest and most generic ones I have...
- pushbikemike
Another vote for hultafors axe from me. Reasonably priced and come in a variety of sizes. I'm a fan of the Bacho Laplander folding saw even for wet wood Ray.
As an alternative you could Take a froe for splitting instead of an axe. Possibly lighter. https://duckduckgo.com/?q=froe&t=iphone ... 0x1000.jpg
- pushbikemike
Same combination of tools for me.Fat tyre kicker wrote:... look at the Hultafors small trekking axe, I have the slightly
still think a wedge makes more sense for backpacking,
I quite like the grenades for actual logs but cannot see the use of one of those in a bothy
- pushbikemike
If you mean the froe, it is ideal for making kindling.Lazarus wrote:its not much use to make kindling which is what I assume they want the axe/wedege for
http://youtu.be/o5daBhSvqSc
If you're looking for a saw then the Silky is the best for me, I think my one is the pocket boy. My laplander is relegated to gardening use
If you need to get a fire going then check out the pocket bellows
Silky Fox saws
