Dynamo wheelset
robbie
Dynamo wheelset
Post by robbie »
I want to get a wheelset / front wheel with a dyno set up. I don't really know much about them. I want to run a light and charge.what do i need and can anybody recomend a set up?
Steezysix
Re: Dynamo wheelset
Post by Steezysix »
Easiest if you can provide a bit more info - what axle size does your bike have and do you want on or off road lighting?
Re: Dynamo wheelset
Choices ...
SP or similar ... my experience isn't very good but others have run them for 1000's of miles without problem. Seem to be something of a lottery.
SON ... seem very good qualty but around twice the price of an SP.
Shimano ... this is what I now use. Not as pretty or as light as the others but much cheaper and so far 100% reliable.
All 3 produce 3w which is ideally what you need if you want to charge (not just run lights). You'll also need some type of charge converter / regulator for charging duties. There's loads of options and prices vary massively. A Kemo is probably the cheapest option and can be had for less than £30.
For off-road lights, it tends to be a Revo or something from K-Lite. If it's a road light, there's much more choice. I've got a Supanova Pro2 which seems good.
Once you start down the dynamo route, it soon becomes quite a minefield ... sadly.
Re: Dynamo wheelset
Any updates on the Velogical bottle dynamo?
robbie
Re: Dynamo wheelset
Post by robbie »
Sorry should have said 700cc for road and gravel riding. 12mm thro axle.
Steezysix
Re: Dynamo wheelset
Post by Steezysix »
12mm axle rules out Shimano, for now at least. You can either go SP (cheaper, potentially unreliable) or Schmidt (expensive but built to last). For road lighting, B&M lights are good and not super expensive, I have an IQ-X which very powerful, and they also make some that can provide USB power output for charging.
dlovett
Re: Dynamo wheelset
Post by dlovett »
SON and B&M Lumix U. Buy once, buy right!!
They will last for years and the light is good enough for off road (non DH) and has a usb port.
Re: Dynamo wheelset
Sorry, keep meaning to write something up but the light nights aren't helping picture opportunities. :wink:
If you're only looking to run lights and maybe do so across a couple of different bikes, then it'd be a decent option. There's virually zero drag but you can disengage it in 2 seconds if you like. It's very light and reasonably easy to fit (be neater / easier if you opted to fit it to the front wheel) and is a very high quality unit.
You can get a little 'humming' at certain speeds - careful alignment reduces it but I've yet to eliminate it completely. Ideally your rim needs to be fairly straight with minimal run-out and any stickers will need to be removed.
robbie
Re: Dynamo wheelset
Post by robbie »
I was looking at the hunt dynamo wheelset. I have a pair of their wheels and think they are alright. Any reviews on the dyno ones?
