Just released today
https://salsacycles.com/bikes/fargo/201 ... i_frameset
How long til it hits the UK shores- guesses??
Fargo Ti 2019
Re: Fargo Ti 2019
Never through a distributor (I’m guessing), however some of the UK independent stores buy direct from QBP (I believe), so that’s probably you’re best betrando nomad wrote:Just released today
Re: Fargo Ti 2019
I was looking at Fargo framesets the other day £800 f&f seems a bit steepBearbonesnorm wrote:... or before anyone can afford one
I'm guessing the ti will be £2k easy
Trying to ride bikes.
Re: Fargo Ti 2019
They usually end up about the same in £ as they are in $ so I'd say about £2800 for the frame and fork, although I see Charlie has them for £2499
https://www.charliethebikemonger.com/sa ... 3588-p.asp
But not sure if that would have been the 2018 model or if there is a difference from last years
Re: Fargo Ti 2019
2019 has an MSRP of $2799sean_iow wrote:They usually end up about the same in £ as they are in $ so I'd say about £2800 for the frame and fork, although I see Charlie has them for £2499
Re: Fargo Ti 2019
4 Gorilla cage mounts on the forks, that's going to look bonkers
