Garmin etrex mount
Al
Garmin etrex mount
Post by Al » Thu Apr 05, 2018 8:34 pm
Had to share this, really simple but really pleased with how it works.
I hate the zip tie mounting brackets - they’re ugly and they never stay put. You can buy spare shoe/cleat things for exposure light brackets from tredz and having had a few of there lights I now have a few brackets on various bikes.
If you pull the rubber underside off the standard mount there is a little square hole. I shaved the rounded corners off the bottom to give it a flat base the pressed a nut into the hole using a vice (after widening a little a Stanley knife). A bit of loctite on the bolt then screwed the shoe / cleat from an exposure light onto the bottom.
The great thing is you can leave the plastic mount attached to the garmin (which it never came out of easy) and just clip it into the light mount.
Al
Re: Garmin etrex mount
Post by Al » Thu Apr 05, 2018 8:35 pm
There must be an easier way to add pictures!
Al
Post by Al » Thu Apr 05, 2018 8:36 pm
Nut in here
Al
Post by Al » Thu Apr 05, 2018 8:37 pm
This nut
Post by Zippy » Thu Apr 05, 2018 10:57 pm
Bravo! Nice to see someone carry through, I only got 80% of the way there!
http://bearbonesbikepacking.co.uk/phpBB ... 93#p145393
Zippy wrote:Interesting Dave. (As you can see, I'm catching up on the forum a bit). I'd been fiddling with an injection moulded one and adapting to suite an exposure mount - with your 3D printing, this could be made to suit exactly!
I got a bit further along than this with a recessed slimline nut and some careful dremelling - I was also going to drill a small hole to attach a tether neatly. This was back in June 2015 though, so R&D is a bit slow :lol:
I intend to go full 3D printed, but it's been in concept stage since 2015 :lol:
restlessshawn
Post by restlessshawn » Fri Apr 06, 2018 11:04 am
Looks good.
I bolted mine to a QR hope light mount so I didn't have to have a bracket on all 3 bikes and when I am not using it there is nothing on the bike. The hope mount uses a smaller bolt by the looks of it as I was able to just sit a small nyloc in that recess without making it bigger.
Warning though...the first one I did I flattened out the bottom of the garmin mount to accept the flat light mount, was fine for about 2 years but then the garmin mount cracked and the whole thing took off. Mk2 I rounded the top of the qr light mount to match the profile of the bottom of the garmin mount and bolted them together with epoxy between them and it's been totally rock solid.
Al
Post by Al » Fri Apr 06, 2018 11:45 am
Nice one - I’ll keep an eye out for that!
