Yay, it's cheery Friday.
Re: Yay, it's cheery Friday.
Way off topic but brought back some memories that made me smile. I was looking through an old backup drive for some pictures and found these
Back in the early 2000s I had a pair of PG Tips monkeys that lived on my desk in the office. I had a running joke with the other engineer that they were in charge of the large format plotter and looked after the day to day running, sorting ink and media changes and ordering supplies. Obviously I did all this but as he never saw me do these things I insisted they did it overnight when we weren't in. When the Beijing Olympics was on (2008) I made them a Tibetan flag as a protest against the Chinese occupation.
The engineer was most impressed by their stance. Later that year I had a week off work and they came home with me as they get the same leave as I do. When we returned this was on my desk where they sit
In this thread it's on topic to be off topic
. And that was cheery so it's on topic anyway.
You and your furry animals, I don't know. Largest one?
Some sunflower seeds turned up in the post, I've no idea where from. Stuck 'em in pots 2 weeks ago and let them rip. I like watching the progress of my little babbies.
I got the pipes for project Death-Trap tacked up. They're curvy, they're bendy, they both run through the down tubes. It makes me cheery.
- BigdummySteve
RIP wrote: ↑Fri May 15, 2020 8:40 am In this thread it's on topic to be off topic. And that was cheery so it's on topic anyway.
A little behind you but these arrived from USA a week ago apparently they are giants!
Sunflower competition is on
- BigdummySteve
Beautiful, I once built a large hydraulic press for rolls Royce aerospace, it had a set of twined valves linked to pressure relief valves. The 10mm pipework had to curve over and around other stuff, a proper head scratcher allowing for all the bend radius.Bearbonesnorm wrote: ↑Fri May 15, 2020 8:54 am I got the pipes for project Death-Trap tacked up. They're curvy, they're bendy, they both run through the down tubes. It makes me cheery.
I bet the exhaust pipes took a similar amount of thought.
sunflower competition - ooer. I'd better start getting some tips about what to feed them then. Raw sewage? Dead mice? Scotch bonnet chilis?
"Project Death Trap" - well at least you're being honest with yourself which is always a good policy
. Almost as curvy as Mrs Perrin they are. And almost as bendy as me.
I like them, I assume they can be removed somehow? It reminds me of one of those Chinese wire puzzles that used to come in christmas crackers where the parts had to be rotated/moved in just the right way to separate themBearbonesnorm wrote: ↑Fri May 15, 2020 8:54 am I got the pipes for project Death-Trap tacked up. They're curvy, they're bendy, they both run through the down tubes. It makes me cheery.
Yeah, they do come off SeanI like them, I assume they can be removed somehow? It reminds me of one of those Chinese wire puzzles that used to come in christmas crackers where the parts had to be rotated/moved in just the right way to separate them
Only two pipes Steve so not that bad really. I had a vague idea of what I wanted but nothing absolute which made the process easier.I bet the exhaust pipes took a similar amount of thought.
Oh. Post lady's just been. Invoice from Lincoln Diesels Ltd for eight cylinder liners. £4080. Plus VAT. You and your cheery.
Ouch, what kind of diameter are those Reg? Are they a press fit or screwed in / held by mechanical means?
Did you bend the pipes yourself Stu or get prebent sections to weld up?
Looks good by the way - I love complex 3D shapes like that!
- BigdummySteve
Is the complex pipe run for ideal length or just for looks? I always wanted to try hydro forming expansion chambers for twostrokes, cut two flat Plates,weld then just pump water in to expand, I had access to a stainless 40000psi pump but never got around to it.
They look really good are they going to double up as foot warmers as well
or will the feet be in a more conventional position
Mainly bought bends with a bit of tweaking Steve. My bender wouldn't have coped and would have creased them. I'd love a good mandrel bender but can't justlfy the cost when I'm only nobbing about and not earning with it.Did you bend the pipes yourself Stu or get prebent sections to weld up?
More the look really Steve but they're actually longer than they appear and equal length give or take a cm or so, so they should work fine ... be pleasantly loud mindIs the complex pipe run for ideal length or just for looks?
Feet'll be well behind 'em.They look really good are they going to double up as foot warmers as well
I did wonder if that was the sum total of the exhaust? When you say 'pleasantly loud' you mean I'll be able to hear it from my house
It isI did wonder if that was the sum total of the exhaust?
I remember when I was 18ish and still lived at home, our neighbor had an AJS 500 single which had a very distinctive sound. He used to ride it every Sunday morning but get out early to avoid the traffic. I wouldn't say the sound of that ticking over for 10 minutes before he left at 06:30 was 'less offensive' but that did depend somewhat on the severity of my hangover
10" press fit. Seals gone, coolant in oil; new rings and a couple of pistons while we're at it. Ker-ching.Bearbonesnorm wrote: ↑Fri May 15, 2020 9:36 am Ouch, what kind of diameter are those Reg? Are they a press fit or screwed in / held by mechanical means?
- BigdummySteve
That’s a piston!
Just had cheery news, The BT Sport studio in Stratford is desperate for in rigging inspection, hopefully I’m going back to work for a week. Had enough of sitting around bored.
My brother works part time at a quarry driving 40 tonne dumper trucks. One morning he sets off and after about 20 metres there’s a bang and the whole thing comes to a rapid stop.
They open up the bonnet to look at the engine and see a 5cm gap between cylinder block and head
It cost them £120,000 (+VAT) to fix.
70mph in a dumper truck
I take it you have a tig welder Stu?Bearbonesnorm wrote: ↑Fri May 15, 2020 8:54 am I got the pipes for project Death-Trap tacked up. They're curvy, they're bendy, they both run through the down tubes. It makes me cheery.
Looking forward to seeing this thing complete
Quote from 'I bought a vampire motorcycle': "Wanna see my choppaaa!"
