Cairngorm loop grp depart 2016
Re: Cairngorm loop grp depart 2016
Ah, so no one used the old two-plank bridge anyway. As you were then.
*nods*ScotRoutes wrote:Ah, so no one used the old two-plank bridge anyway. As you were then.
*Drinks tea*
*Wanders around internet on works time*
Easter is fun in a university.
Take a bike in and set some Strava KOMs in the corridors?
- Dave Barter
I need to update the maps. It's on the list after learning Portuguese.
Interesting idea...the main lab space has quite a thin roof.ScotRoutes wrote:Take a bike in and set some Strava KOMs in the corridors?
Having only ever been in to Glen Feshie once, some questions (I'm at work and the boss sits next to me so firing up a GPX trace isn't a good idea
I know where the Allt Garbhlach is, I think we crossed it further uphill and took a faint track through the woods. Where is/was the two plank shonky bridge?
I don't recognise the "new" track undercut by the river in the second of Colin's shots, again I think we were further away from the river (shots 4 - 6 here - http://bobwightman.co.uk/bike/slideshow ... glenfeshie) so were we following the line of the CL route?
Finally any news of the state of the track beyond the bothy?
- ZeroDarkBivi
Just had a look at this - I thought the end was the Blair Atholl train station, but there appears to be an odd 15km wiggle after that. Anbody able to clarify?GregMay wrote:Route is as per GPX: http://cairngormsloop.net/map.html
The end is at the clock at the station - Which is not where it starts from. Is that possibly your difference?ZeroDarkBivi wrote:Just had a look at this - I thought the end was the Blair Atholl train station, but there appears to be an odd 15km wiggle after that. Anbody able to clarify?GregMay wrote:Route is as per GPX: http://cairngormsloop.net/map.html
- Single Speed George
AM I JUST GOING TO GET WILDLY LOST FOLLOWING MY GPS TRACK FROM THE WEBSITE AND FALL IN A RIVER IN THE DARK THEN ?
[URL=http://veloviewer.com/athlete/1646483/]
[/URL
Hopefully Mr. Shouty Man.Single Speed George wrote:AM I JUST GOING TO GET WILDLY LOST FOLLOWING MY GPS TRACK FROM THE WEBSITE AND FALL IN A RIVER IN THE DARK THEN ?
Sorry caps lock, but ye hopefully it is easier to route find that seems to be begin made out here
by just following the gpx and avoiding the erosion?
[/URL
I'm going to remove the wee wall of stones and hope to retrieve some nice bikes and bikepacking gear out of the Feshie
I've got a trailer if you need a hand Colin
When I did the route in 2013, I followed the new path from ruigh etchacan bothy to the road alongside the feshie. Steve was cool with that as this is 'the path' and the old route that the GPX follows is now redundant. Interesting that the new path, supposedly built well away from the river to avoid future erosion has fallen into it...
Another thing worth noting is on the run out to Glenmore from Blair Atholl on the west side of the feshie. At the houses at Ballintean the gpx follows the old route of the right of way to the east of the houses but this was diverted a few years ago when a new house was built. It now goes through the houses on a slight dog leg and is well signed from the road. You can still get through on the gpx route but I took the view that you should follow the signed path rather than the old ROW.
The path on the ground as you approach and leave the Eidart bridge on the Geldie / Feshie section also deviates from the path line on the map which the GPX file follows. Again I took the view of following the path on the ground rather than trying to fight your way along a route that pretty much doesn't exist. I reckon this path will be next on COATs list to sort as its getting pretty heavily eroded and sees a lot of use so it will be interesting to see which line they take.
Looking forward to it but I wish the start time was earlier so I can make the Aviemore chippy at the end of day 1
Is it worth asking Steve for an early start?
I've never made it to Aviemore on day 1 - first time I camped about half a mile from the bothy, not knowing it existed (oops) and then second time in the bothy.
FWIW, the crossing point of the old path has a similar steep drop after that area was also swept away.htrider wrote:When I did the route in 2013, I followed the new path from ruigh etchacan bothy to the road alongside the feshie. Steve was cool with that as this is 'the path' and the old route that the GPX follows is now redundant. Interesting that the new path, supposedly built well away from the river to avoid future erosion has fallen into it...
(but perhaps I've said too much already....)
Can you carry the body bags in?Gari wrote:I've got a trailer if you need a hand Colin
Would an updated GPS file be possible to produce that accounted for some / all of the changes in the course? There were a few times in 2013 where I was wandering about trying to find the 'path' where none existed. I just followed the GPS as exactly as possible, but it was weird to have to leave a good path and wander thru a new plantation / someones garden etc...
Nikk wrote:Would an updated GPS file be possible to produce that accounted for some / all of the changes in the course? There were a few times in 2013 where I was wandering about trying to find the 'path' where none existed. I just followed the GPS as exactly as possible, but it was weird to have to leave a good path and wander thru a new plantation / someones garden etc...
Probably worth emailing Steve - seeing as it's his "thing" .
FWIW, I'm not certain it needs to be any more detailed than it is. Common sense should prevail - if the GPS trace goes that way - and you're 10-50m off to the side but still going that way, it's all good.
so the slight path changes etc are pretty obvious on the ground (in daylight anyway) where new tracks go etc ?GregMay wrote: FWIW, I'm not certain it needs to be any more detailed than it is. Common sense should prevail - if the GPS trace goes that way - and you're 10-50m off to the side but still going that way, it's all good.
[/URL
Where the newer path is in Feshie you'll struggle to find the old one.
Chris, sorry for delay in responding. I did the section from Dunbar back to Edinburgh. All the "walking" bits were rideable, a bit muddy, a bit sandy, and you could even practice getting wet through a ford ( I used the footbridge!), and I think the road alternative is only for people who won't go off a hard surface. You have to concentrate in Edinburgh to not lose the path and it's not much fun in the traffic really. I was running out of time so I actually stayed on the canal to get back to Falkirk. I don't know what it's like in the west. Hope that helps.Justchris wrote:I was looking at the John Muir Way yesterday when I should have been working, I had actually never come across it before. I was wondering if the bits that are cycling alternatives were too easy and just do the 'walking' bits, or stick to them.Howard wrote:Got the opportunity to do some training on the John Muir Way on Sunday. There's a nice section of undulating sandy single track - at times as easy as cycling through mud. It's only about 10m from the road and every one of the dozen or so roadies who went past on the tarmac looked at me as if I was a nutter
Chris
I'll admit to getting slightly confused by the GPX track at the crossing in feshie last year.ScotRoutes wrote:Where the newer path is in Feshie you'll struggle to find the old one.
In my defence, it was 10pm by the time I got there - it was dark and I was tired
Dropping my son of in Perth on Friday for the youth tour of Scotland and planning to sneak off and ride the route before I collect him on Monday so should be able to see which bits still exist
