Glad they arrived ok, that picture makes you realise how narrow they are in relation to the newer loops!
Nah, there's bugger all in it.....it's like the classic which one is bigger illusion:Gari wrote:Glad they arrived ok, that picture makes you realise how narrow they are in relation to the newer loops!
Thanks to Shona and Rich over at keep pedalling a lovely Dynamo wheel arrived this week, went for the crest rim and SP PD-8x hub, so thanks for the comments on here when I was deciding!
Now to get a tyre on it!
Drew
Drew
- JohnClimber
Collected an Exped Downmat Lite 5LW matress from Ultralight Outdoor Gear as I was in the area.
I went for the W(ide) because when I sleep on my back my elbows fall off the side of my Neo Air waking me up each time.
An Exped Synmat Winterlite sleeping mat from downsleepingbag.co.uk.
A brilliant russian doll of revelate kit crammed in a Viscacha from Cycletribes!
So you're the mysterious winnerjohnnystorm wrote:A brilliant russian doll of revelate kit crammed in a Viscacha from Cycletribes!
-Arcteryx windshirt for the wifey for her birthday (was a bargain with two thirds off)
-Arcteryx alps comp jacket for me for Xmas (so o won't be able to use until then!)
-2x Crikey, how much bidons
-1x Crikey, how much mug
-Crikey, how much mobile phone case
Had some vouchers for Crikey, how much, so spent it on lifestyle products
Just hidden the wife's jacket away but no doubt she'll find it before her birthday in January!!!!
An accidental eBay win of a 29+ wheel. Dunno why I bought it as I don't really need a spare but hey...
A bit late now, but I've had a few things turn up recently
new Stans tubeless valves after my other one buggered up
more Stans fluid
Exposure Diablo - very pleased with this!
There's more but I just can't remember
more Stans fluid
A prototype, 3 mount Gorilla cage mounting adaptor has just arrived ... looks smashing and should be ideal for those without cage mounts on their forks.
Revo returned from Exposure after I put the wrong wire into the output port and borked it.
£14.50 repaired and posted for being a muppet.
Ah - I'd just received a reply to the email, that I'd sent to Parable, asking if they were going to make those (and they replied positively)A prototype, 3 mount Gorilla cage mounting adaptor has just arrive
Glad to see that you're in the loop, and look forward to hearing your opinions.
In the loop, I should say so ... who's idea do you think the Gorilla cage was?Glad to see that you're in the loop, and look forward to hearing your opinions.
- whonickedmename
I had a set of barely used on one fat wheels from ebay and a roll of bright orange reflective tape for when I drill them out
Any chance of a picture or two?Bearbonesnorm wrote:A prototype, 3 mount Gorilla cage mounting adaptor has just arrived ... looks smashing and should be ideal for those without cage mounts on their forks.
It attaches with 4 cable ties ... they pull in opposing directions which is a nice touch. The rear is concave and has rubber pads to help prevent any slippage. So far, it's fitted every fork I've tried it on. I still need to try it properly but I have high hopes.Any chance of a picture or two?
That looks neat. Have you just been trying it on round/oval type forks (i.e. most steel models) or carbon blade type ones as well?
Would it fit on a seatstay?
That would be a touch dangerous wouldn't it? The angle would mean it might flip down and into the wheel. Although probably OK for something lightBen98 wrote:Would it fit on a seatstay?
Forks at least at (mostly) vertical
Not tried it on monocoque type forks. I don't think it would fit straight on but I'm sure it would with a little padding to flatten the rear out.Have you just been trying it on round/oval type forks (i.e. most steel models) or carbon blade type ones as well?
Got mines this afternoon, lovelyJohnClimber wrote:Aldi tomorrow
5200mAh Powerbank just £8.99
