FS: Surplus Wildcat Gear (more added)
Re: FS: Surplus Wildcat Gear (more added)
Funds and PM sent.
Thanks.
Thanks.
Hi Ian,
I'll take the Alpkit Airlock Xtra dry bags: 8 litre (black) and 3 litre (red) if they're still available?
Sean
Sean
They are, or were - you've just bought themseanroy wrote:Hi Ian,
Sean
- whonickedmename
Hi Ian,
Can you give me the dimensions of the Alpkit fuel pod please? Will take it subject to these...
Cheers,
David
Cheers,
David
David,
It measures 22cm long, 4cm wide and 11cm high
- whonickedmename
Hi Ian,
Thanks, that's fine.
Ok if if PP you £15 and I pay the fees?
Perfect, thanks
There's a link in the original post that allows you to send me a payment. Send me your address too and I'll get it posted.
- whonickedmename
Ian - PP sent with address, thanks
Got it, thanks. Will post tomorrow.
The long thin Ocelot frame bag arrived safely.
Excellent quality and service, as always!
Cheers all and good luck with the move.
Adam.
Adam.
When you gonna add a digi camo Lion with tongue and matching integrated Lioness (clip on)
When Ian ???? When!!
I think that's what Taylor has?Matt wrote:When you gonna add a digi camo Lion
Not before I've moved to Scotland!Matt wrote:When you gonna add a digi camo Lion with tongue and matching integrated Lioness (clip on)
Hi Ian,
Is the dual zip frame bag still available?
Cheers,
Andy
Cheers,
Andy
Andy, yes it isRoobell7 wrote:Hi Ian,
Cheers,
Andy
I'll give it a go IanIan wrote:Andy, yes it isRoobell7 wrote:Hi Ian,
Cheers,
Andy
Cheers Andy - I've sent you a PM
Quick round up of what's left:
Wildcat Framebag - Black - single compartment only, cut out for full suspension rear shock (or possibly a small water bottle). Think this was done for a Turner Flux, or similar judging by the little strap at the rear of the top tube.
TT: 45 cm
DT: 44 cm
ST: 28 cm (effectively)
£40
Revelate dry bag for a Terrapin. Unused, storage marks only. £25
Postage at cost (about £3.90, second class recorded)
TT: 45 cm
DT: 44 cm
£40
Almost but worth itRoobell7 wrote:I'll give it a go IanIan wrote:Andy, yes it isRoobell7 wrote:Hi Ian,
Cheers,
AndyIs postage £5?
Ian,
Do you have instructions on how to fit the 'Wildcat Tiger Drover' please ?
Thanks,
Bill
Thanks,
Bill
Perfect.
Thanks Zippy
Ian,
Apologies but I am in buckle hell.
I've got it all sorted except for buckle 'd'
For the life of me I can not thread the strap in to the buckle & get it to stay tight.
I am sure there will be plenty there tomorrow to help including Karl & Pete, but thought I'd ask anyway.
Got a photo?
Buckle d is a normal tension lock, so pass through the underside, closest to where it attached to the bag, loop through the front and back under behind the curved thumb release end. Pull tight, and it shouldn't undo.
