Harnesses that play nice with a Jones bar
stevenshand
Re: Harnesses that play nice with a Jones bar
Post by stevenshand »
htrider wrote: Mon May 17, 2021 10:16 am I found with my wildcat harness that the straps rubbed against the lower headset cup, and any bag in it rubbed against the head tube, likely due to me using a 50mm stem. I bolted on one of those Ortleib light bars onto the fork crown - just a plastic bar spaced out about an inch - and attached the lower straps to this. This gave a solid set up, didn't rub paint off the fork crown or head tube and made the harness easy to remove as you just loosened the straps and popped them off the end of the bar thingy.
I also strap the bar roll to the rear loop with foam blocks so you can still hold it. Having a truss fork further aids bar roll stability :mrgreen:
This is definitely our experience as we see people using shorter and shorter stems. It's still not something that would put me off but I'd suggest just checking where the rub points are more likely to happen and take any precautions (eg protective tape).
Mart
Post by Mart »
Both my revelate harness and salsa anything cradle work very nicely on loops
marcinski
Post by marcinski »
Triglav Packman already has front loops that play nicely with the Jones bar:
That's how I use mine.
Marcin
