Fat Fighters 2021
Re: Fat Fighters 2021
Nice work there
1/1/21: 117.7kg
8/1/21: 116.8kg
0.9kg (practically 2lbs) down this week after the big pre-official start loss so I’m happy with that. Trying to be sensible enough with food intake that I don’t break and binge, and sensible enough with exercise that I don’t bust and binge on food being tired, achy and fed up.
I'm sticking with 2000cals, but I could have made better food choices to eat more low calorie bulky stuff, but the odd bag of crisps has been savoured more than 3lbs of salad would ever have been
Onwards and downwards!
8/1/21: 116.8kg
85.9kg (Jan 1st) then a midweek weight to spur me on.
84.0kg (Jan 8th)
84.0kg (Jan 8th)
Start 01/01/21, 97.7kg
Today 15/01/21, 97.7kg
Maintaining again. Excercise levels are ok, eating habits are poor. So happy, but do need to get on with it.
I spend a bit of time worrying that if i lower my calorie intake ill just flop around out of energy as im knackered all the time already...
26/12/2020: 121.7kg
1/1/21: 117.7kg
8/1/21: 116.8kg
15/1/2021: 115.5kg
1.3kg down this week
Still a long way to go though for this big bear.
6.2kg since boxing day! That first week there was obviously a lot of water loss and emptying of the system.
2000-2400 cals a day depending on exercise done and tracking with mfp.
1/1/21: 117.7kg
8/1/21: 116.8kg
15/1/2021: 115.5kg
- gairym
15-01-21 - 114.2kg
08-01-21 - 114.8kg
01-01-21 - 115.4kg
Gently moving in the right direction but not enough being done.
No booze, less crap (though not zero crap) BUT work coupled with the curfew (was 20h now 18h) not really allowing for any exercise at the minute - crap!
I'll keep at it.....
08-01-21 - 114.8kg
01-01-21 - 115.4kg
Well done chaps.
Ill try harder this week, dont want to let the side down!
- gairym
So.....I had a little look through the previous Fat Fighters threads and it appears I'm not very good at losing weight but fairly handy at putting it on
With a little luck (a lot of sensible choices and no small amount of restraint) I've turned a corner with last years bigger loss.
2017
Start = 110kg
Finish = 109kg
2018
Start = 111kg
Finish = 113kg
2019
Start = 115.9kg
Finish = ???
2020
Start = 118kg
Finish = 113kg
Cheers and well done too
Come on people, please can we all start pulling our weightWell done chaps.
In other news...
84.0kg (Jan 8th)
83.1kg (Jan 15th) the power of not scoffing biscuits & chocs!
31/12/2020 76.5
8/1/2021 75.1
15/1/2021 74.1
According to MFP I should only be losing 0.5kg a week so my numbers are off somewhere. I did have a drink this week, albeit only the one, I've cut out most of the snacks but allowing myself a small chocolate ration, two if I do exercise, seems to be working. All bar one main meal this week has coincidentally been vegetarian so not sure if that's making a difference.
8/1/2021 75.1
15/1/2021 74.1
- gairym
I find I lose weight faster without meat BUT I do find I run low on energy too.
I also find that any weigh-in within 24-36 hours of a big meaty meal has me up as I think it's all just sat there digesting slowly...
No idea if it's true, but I have read that we can have 3-4kg of meat going through the digestive system very slowly. One thing about weighing yourself on Fridays is that I've learnt to avoid a big roast / barbeque / takeaway on a Thursday to make the numbers look better
- 99percentchimp
I'll have another crack at this this year... poor show last year!
115.2kg - 1.1.2021
114.5kg - 8.1.2021
113.2kg - 15.1.2021
Oh yeah Goals... same as Gairy from roughly the same starting point this year
115.2kg - 1.1.2021
114.5kg - 8.1.2021
113.2kg - 15.1.2021
Was 84kg when I was climbing a lot and a few years ago got down to 96kg successfully so I know it's achievable if I am consistent in approach and I know what works for me (sort of!)Post by gairym » Fri Jan 01, 2021 2:12 pm
1st goal: at least 1kg loss each month (ideally much more)
2nd goal: be under 100kg by the end of the year.
Final goal: get down to 95kg and then stay between 95-100kg forever and live happily ever after.....
Conquistador of the pointless
- gairym
99percentchimp wrote: ↑Fri Jan 15, 2021 5:23 pmOh yeah Goals... same as Gairy from roughly the same starting point this year
Last one to 100kg gets the (low calorie) beers in.....
- 99percentchimp
You’re on!gairym wrote: ↑Fri Jan 15, 2021 8:51 pm99percentchimp wrote: ↑Fri Jan 15, 2021 5:23 pmOh yeah Goals... same as Gairy from roughly the same starting point this year
Start 144kg
8/01/21 - 144kg
22/01/21 - 148kg
Not had a good couple of weeks, but I am feeling stronger than when I started. I need my snack game has improved, I still need portion control.
8/01/21 - 144kg
22/01/21 - 148kg
Simon K
- gairym
22-01-21 - 114.3kg
15-01-21 - 114.2kg
08-01-21 - 114.8kg
01-01-21 - 115.4kg
No surprise there's no loss this week as I've been up against a project deadline so eating has been a snatch and grab affair when time has allowed.
Been a bit more active too.
Managed to get out twice on the splitboard and one turbo (evil misery!) session.
No complaints, mostly behaving and on target for 1kg loss for the month.
15-01-21 - 114.2kg
08-01-21 - 114.8kg
01-01-21 - 115.4kg
26/12/2020: 121.7kg
1/1/2021: 117.7kg
8/1/2021: 116.8kg
15/1/2021: 115.5kg
22/1/2021: 113.6kg
Wow 1.9kg this week. Didn't expect that! Long way to go though.
Keep it up guys
1/1/2021: 117.7kg
8/1/2021: 116.8kg
15/1/2021: 115.5kg
22/1/2021: 113.6kg
Keep it up guys
8/1/2021 75.1
15/1/2021 74.1
22/1/2021 73.9
Small loss this week - similar calorie intake and exercise as last week but much higher meat content. Hohum, onwards and downwards so to speak.
15/1/2021 74.1
22/1/2021 73.9
Is there room to squeeze in another 90kg. Since March last year I've been the carer for an elderly parent and between that, work and everything else that's going on things have literally gone pear shaped. There's been an increase in weight but disturbingly what was there already has moved about and is now in places it shouldn't be. So long term want to drop 10kg but want to also get back to a healthier lifestyle.
Today 22/01/21, 97.5kg
I tried a bit harder, honest..... 0,2 though...
- 99percentchimp
115.2kg - 1.1.2021
114.5kg - 8.1.2021
113.2kg - 15.1.2021
111.1kg - 22.01.2021
Slow steady progress so far and feeling much better for it. Aiming to be back under 110kg next week but I suspect the hard yards come soon!
114.5kg - 8.1.2021
113.2kg - 15.1.2021
