Well, being as Snowpeak has already been mentioned, I have had for some considerable time a rather lovely Snowpeak ti cafetiere thing. Won't do any of your other requirements but does make a smashing cup of coffeeEven though I have a complete coffee addiction...
Nesting Ti Pots...
Re: Nesting Ti Pots...
- Bearlegged
In my experience that makes it harder to clean. I stopped putting chocolate in my Ti because it started getting welded on.
If you don't care about chocolatey meals I guess that's not an issue though.
- Bearlegged
Hmm, not a problem I've encountered so far. The only time I'm applying heat to the mug is to boil water, and I wipe it clean immediately after use. Will keep an eye on it though, ta.
I must admit I concur with RG - I've found it does tend to get welded on no matter how much grass I clean it with. I use the last dregs of the hot water to wash the plastic pot. Mixing the drink in the Ti, as well as the porage in the plastic, then rebuilding the russian doll afterwards without washing them leaves one with an amusing mess to clear up later...
