Podsacs saddle bag ?
Re: Podsacs saddle bag ?
Thanks will have a go at those tips.
I ordered one earlier as an entry into bikepacking.
Looking forwards to trying it out when I get back from Switzerland!
Just had an email with Friday special offers, the frame bag is reduced to £10 for the small and £15 for the medium, worth a punt at that!
- ZeroDarkBivi
Anybody tried the bar bag? I need something more durable, and too tight to splash out on the Ortileb bag.
I had 2 of the podsac dry bags for the fork. They was waterproof alright as I tested it with around 4kg of water. It was literally like a bucket and the weight reflected that... I imagine, going by what I had, this saddlepacks gonna weighin at around the 1kg mark...
I bought one of the Podsacs saddle bags for Joe when they were £25 from PlanetX. We took it away for two months and gave it some serious testing. I was so impressed with it that I am thinking of selling my 16l Ortlieb and getting one for myself.
Good points in no particular order:
Its only about 600g so a bit heavier than the Ortlieb (which has a bigger capacity), but not much. It feels stronger and more robust though as it is made from a heavier fabric.
It is very waterproof.
It doesn't sway.
It is possible to open it and get something out while it is still on the bike without it collapsing and spilling all your stuff over the dirt.
It sits up nicely away from the tyre and acts as a very functional mudguard.
The straps don't work loose during a ride. They are also easy to tighten and the buckles release easily.
Negative points:
Only one - if the bag is full then the light mounting point is in the wrong place.
It doesn't sway.
Negative points:
I had the same bag and also couldn't fault it except for I broke a buckle on it after 6 months daily use ( on commute) but can't really moan about that
