A trip to RCC in Skipton saw me a new lazer genesis helmet, crank Bros stem and some Morgan blue cleaning stuff
Saw that on twitter. Nice one.A trip to RCC in Skipton saw me a new lazer genesis helmet, crank Bros stem and some Morgan blue cleaning stuff
Blog - thecyclerider.com
It's super model stick thin fitting imho. I can't see many adults full stop fitting in it!voodoo_simon wrote:Hmmm, I'll check availability tomorrow in work and I'll have a think. Medium women's must be a size 12, which should fit me (can't believe I'm typing this...) How much did it set you back?
Was hoping to just use flasks and keep my back free?! Hmmm, decisions
Not sure at this stage. Depends on conditions. If baltic, I might take a small flask for hot watervoodoo_simon wrote:Are you taking any other water carrier device Ian?
Haglofs kindly sent us this little bundle today.
- Blackhound
Went to Alpkit towers this week to collect a bicycle 7 that Ben sewed a kador strip to to give me an overnight awning for the camper van.
Postie has brought a micro grip for my ti pots as suggested by Ms Wench.
Montane Bat Pack 6 bum bag.
And finally a Klymit x mat weighing <300 grams for summer months.
Saw the prices of this camelbak vests, think I'll stick with my flask option. Which leads me into my new goodies
-2x lifeventure flasks 700ml (with grippy outer so good for gloves)
-10 speed chain and cassette
-New gear+ brake cables
Alpkit bicycle 3.5 and some string
- (98.27 KiB) Downloaded 2638 times
Howies Dyfi came the other day, orange and muddy
(Sent by Stuart, left it at the FF)
You could save a 'noticable' amount of weight and reduce packsize by using different line and ditching the clippers.whitestone wrote:Alpkit bicycle 3.5 and some string
s8tannorm wrote:You could save a 'noticable' amount of weight and reduce packsize by using different line and ditching the clippers.whitestone wrote:Alpkit bicycle 3.5 and some string
Need to have a play
Tree Surgeon's throw line is good, particularly if you can be bothered to splice it. Very easy and lots of useful info on the internet or hammockforums.net.
Throw line like this (other diameters and colours are available):
http://www.frjonesandson.co.uk/products ... 1-5mm-50m/
30t thick/thin ring and a KMC chain ... turns out I didn't really need the ring as the KMC chain works perfectly with my On-One T/T ring whereas Sram and Shimano refused to play nicely
For my Rig3.5 I use 4 short guys for the corners. 2 long ones that are the main guys for wrapping round the tops of poles, and I made 2 tie outs that are midway along the long sides. I have a bit more info in this post. http://www.composite-projects.co.uk/201 ... -3-5-tarp/whitestone wrote:Alpkit bicycle 3.5 and some string
4 inner tubes, approximately half the weight of my current ones.
A Park Tools digital scale - a long lusted after item for the garage
- summittoppler
Swift service from Alpkit, got my hands on a medium Fuel Pod for stashing the camera' in when out and about and I've also made my first titanium purchase, the new Kelvin.
- JohnClimber
Just hope their not twice as easy to punctureIan wrote:4 inner tubes, approximately half the weight of my current ones.
- gairym
The postie arrived today with a replacement Exposure 'Joystick' after some moron (me!) lost mine at the FF (after putting it on backwards and parading around like a proper goon!).
There's a life lesson in there somewhere.....
Mine is tied to my helmet via a length if very thin spectra cord. I have made use of it several time!gairym wrote:The postie arrived today with a replacement Exposure 'Joystick' after some moron (me!) lost mine at the FF (after putting it on backwards and parading around like a proper goon!).
- gairym
Mine will be fastened on extremely securely from now on, of that you can be sure!
- TheBrownDog
DPD delivered a set of Surly ECR forks. I'm building a frankenbike. Should be fun.
The postie has apparently been to work with a frame and my hub spares
Unfortunately, I have not gotten to work again.
Singlespeed all weekend then.
Jumped in after lurking here a while
Over the last week...
2x snugpak travelpak 3
2x Hunka XL
2x 20L Airlok Xtra
1x 13l Airlok Xtra
1x tapered Airlok
1x Koala
TravelTap
Then today
NeoAir Xlite
Rig7 + paracord and Ypegs
Gourdon 20L
Just waiting for my sis to post me her spare mat and I'll be set for adventures with my 9yr old.
2x Hunka XL
2x 20L Airlok Xtra
1x 13l Airlok Xtra
1x tapered Airlok
1x Koala
TravelTap
Then today
NeoAir Xlite
Gourdon 20L
That carbon pole as re sparked my interest in them as that's come in lighter than I Stu quoted :0)
