Tour Divide 2016
Re: Tour Divide 2016
Greg, I had a KCNC mount like that. I found it very thin - easy to over tighten the bolts and crush the tube, plus I think it was damaged by vibration, meaning a repeated cycle of tightening and crushed wobbly tube. I have a carbon tubed one now that I'm actually not using 'cos I only needed it with straight bars, but from the use its had is much tougher.GregMay wrote:Nope, one mounts the light - Plug3 and it's internals. The other raises up the eTrex which is now glued to it's bracket and has the back Dremmeled to get to the quarter turn screw for the battery compartment.ctznsmith wrote:Have you mounted one KCNC smart bar to the other?
Mines squashed too, but I went otb and it landed on the exposure six pack mounted on it...
Do you really need the flower pot ... I'm guessing you won't end up using it.
I'm thinking of the prospect of a longer ride and growing food on the way. The windmill is an additional dynamo to power my fairy lights.
ianfitz wrote:Greg, I had a KCNC mount like that. I found it very thin - easy to over tighten the bolts and crush the tube, plus I think it was damaged by vibration, meaning a repeated cycle of tightening and crushed wobbly tube. I have a carbon tubed one now that I'm actually not using 'cos I only needed it with straight bars, but from the use its had is much tougher.GregMay wrote:Nope, one mounts the light - Plug3 and it's internals. The other raises up the eTrex which is now glued to it's bracket and has the back Dremmeled to get to the quarter turn screw for the battery compartment.ctznsmith wrote:Have you mounted one KCNC smart bar to the other?
After 5,600km with them this year...I'm pretty confident they work for what I'm using them for.
EDIT: De-snarking comment - i agree they are a bit flimsy, but I'd already come to that conclusion and not overtightened them. Also, they are being used to store things internally, so they serve a second purpose. I took some time to bulk out the one with the Revo with some internal bracing too.
You do seem to have thought about your build 'a bit'GregMay wrote:ianfitz wrote:Greg, I had a KCNC mount like that. I found it very thin - easy to over tighten the bolts and crush the tube, plus I think it was damaged by vibration, meaning a repeated cycle of tightening and crushed wobbly tube. I have a carbon tubed one now that I'm actually not using 'cos I only needed it with straight bars, but from the use its had is much tougher.GregMay wrote:Nope, one mounts the light - Plug3 and it's internals. The other raises up the eTrex which is now glued to it's bracket and has the back Dremmeled to get to the quarter turn screw for the battery compartment.ctznsmith wrote:Have you mounted one KCNC smart bar to the other?
You're talking to the king of the cack handed. Beware my vaguely exciting skills of destruction.ianfitz wrote: You do seem to have thought about your build 'a bit'so I figured you would have tested it. I think I was a bit cack-handed/over keen with mine...
A couple of names have appeared...GregMay wrote:Looks like the race tracker is up: http://trackleaders.com/tourdivide16
Bike back from servicing from Keep Pedalling. Throwing bags on to take photos of setup and kit list. The usual is in place.
Simple Really by Greg.May, on Flickr
- mountainbaker
Best of luck guys, knowing that you're all about to embark on the divide is making me very nostalgic for it, and now thinking about racing again next year.
Try not to do what I did on day 1, ride through a nasty bear sh¡t, flick it up all over your leg without noticing, feel something on your leg, wipe if off with your glove. That glove smelt pretty bad for the next couple of weeks
Gets under yer skin, eh? :)mountainbaker wrote:...and now thinking about racing again next year...
For those that are racing this year, I hope you like your washboard with a side of gravel and your vistas vast. You're about to get that by the bucketload. Don't let the bears freak you out.
Where you in the woods?mountainbaker wrote: Try not to do what I did on day 1, ride through a nasty bear sh¡t, flick it up all over your leg without noticing, feel something on your leg, wipe if off with your glove. That glove smelt pretty bad for the next couple of weeks
But all i wantz is a snuggle mr. Bear!Scattamah wrote: Don't let the bears freak you out.
An interesting list. As you say a lot is about knowing how you handle particular weather/environment and looking after yourself and your bike. I'm fine with cold and heat but not humidity. Anyway back to spot watching, I mean work.
Batteries are heavy. I'd say go with 1 spare set of AAA's for SPOT and 1 spare set of AA's for Etrex. Resupply on route as required. Same with your brake pads unless they're really tricky to source. Even in the mire of 2014, I needed to change brake pads just the once in Steamboat @ Orange Peel. If they're Shimano pads, and you're towards the front, you should be fine.
Scattamah wrote:Batteries are heavy. I'd say go with 1 spare set of AAA's for SPOT and 1 spare set of AA's for Etrex. Resupply on route as required. Same with your brake pads unless they're really tricky to source. Even in the mire of 2014, I needed to change brake pads just the once in Steamboat @ Orange Peel. If they're Shimano pads, and you're towards the front, you should be fine.
Batteries are a juggle point for me at the moment - they are quite heavy I agree. Pads, I'm taking spares, as I run BB7s and they tend to shred if it gets muddy, even with sintered pads.
EDIT: Cache battery is now not the big one BTW, much smaller one that I tested at the weekend, mainly used to charge the camera and Exposure Support cell for the eTrex - my Joystick does not like acting as a battery, despite having SmartPort on - not fussed though.
I'm taking a set of AAAs in my Spot and hoping to run it off the dynamo. My spare blinky light and head torch use AAAs too so they're spares in effect. I'm taking a pair of AAs to go in my Dakota. Lithium batteries seem loads lighter. I'm taking a load of brake pads as they weigh nowt and take up no space and I've suffered from running short before.
I think the peace of mind will outweigh the extra ballast!
7.5g for an AAA - 15.6g for an AAjohnnystorm wrote: Lithium batteries seem loads lighter.
*hangs head in shame*
Still surprised the Joystick won't charge from the Plug
On the electrics... is there any issue with the plug mounted in that orientation, water/grit sitting in the port?
I'm not 100% convinced the Plug gives out a constant 5v that the Exposure kit likes -even on the road - but it gives enough to charge the cache battery.atk wrote:Still surprised the Joystick won't charge from the Plug![]()
Had no issue with grit/water ingress - supposed to be ok with it...and has been so far, but still, in heavy rain, it'll have its cover on.
