voodoo_simon wrote: A brown box...
...with Salsa printed on the side...
...and a Mukluk frameset inside....
:D
Stu will soon be getting
A brown box...
...and a Raleigh Shopper inside...
:lol:
Blackhound
Post by Blackhound »
AFter the thread last week I ordered a Sawyer mini filter. just need to test it.
New vinyl of Scud Mountain Boys latest album arrived in same delivery ;-)
P1131280 by blackhound59, on Flickr
He's a lucky boy :lol:
Taylor
Post by Taylor »
15mm bolt through arrived this afternoon,Image
That for the new bike? ... what forks is it having?
If it's for your Giant ignore me obviously.
Taylor
Post by Taylor »
15mm for the Giant with an adaptor to reduce to 9mm quick release to fit the Fargo fork.
ianfitz
Post by ianfitz »
Make sure you measure the adaptor first. The hubs are not 100 mm wide but the adapters are!
Mine was turned down by the good fellows at 18 bikes. Before that the hub wasn't clamped and the connector span round veeeery slowly and ripped the cable out.
Taylor
Post by Taylor »
I looked at that earlier and it does seem to sit a gnats wider than the hub.
composite
Post by composite »
Best way of shortening it?
ianfitz wrote:Make sure you measure the adaptor first. The hubs are not 100 mm wide but the adapters are!
I don't quite understand this - can you elaborate please :?
flatfishy wrote:I looked at that earlier and it does seem to sit a gnats wider than the hub.
Unsure what "that" and "it" are :?
Yours muchly confused,
flatfishy wrote:15mm bolt through arrived this afternoon,Image
That looks luverly but the subsequent "it don't fit" comments sound a bit ooer :oops:
Finally got a delivery from the States yesterday. I doubled up between Enlightened's sale and a request to Brandon at Warbonnet so yesterday received a lovely 3/4s lynx UQ with 1oz overstuff.
Taylor
Post by Taylor »
The adaptor sit's slightly proud of the hub so the forks don't clamp the hub correctly allowing the connector to rotate which eventually pulled the wires out of the plug in the hub.
All it requires is a couple of minutes and a lathe to turn the adaptor down about .5mm.
Not a big problem.
composite
Post by composite »
Hmm I have no lathe to hand, I wonder if the QR adaptors for my other 15mm hub will fit. I guess they should.
Just hit 'em with a file ... even the most inept should be able to file .5mm off a spacer and keep it flat ;)
In the last week I have received:
3 * Fiskars Brush Hooks
2 * Sledge Hammer (short handled, 3lb)
2* Drain spade (fibreglass handle)
4 * Digging Spade
1 * Rubber mallet
4* Wolf Garten - Soil Rake heads (30cm)
4* Wolf Garten - Pruning Saw
4 * Wolf Garten - Aluminium handles (150cm)
2 * Silky - Gomatoro Root Saw
3 * Silky - Gomatoro Root Saw - spare blade
2* Silky Gomatoro - Pruning Saw
3 * Shovels (round point), D handled
3 * Shovels (round point), long handled, fibreglass
3 * Azadas (light, medium)
2 * Azadas (pick style)
2 * Azadas (pointed / drainage)
3 * Ghillie Kettles
3* First aid kits
Kitting out / re-stocking 3 volunteer trailbuilding and maintenance teams. My garage is very full at the mo!
adjustablewench
Post by adjustablewench »
Before I read the last line I imagined you were some kind of manic diy obsessed octopus . . .
I just read "...maniac..." and wondered when we met ;)
I admit though that after years of trailbuilding I have a bit of a fetish for shovels and stuff :oops:
ianfitz
Post by ianfitz »
flatfishy wrote:The adaptor sit's slightly proud of the hub so the forks don't clamp the hub correctly allowing the connector to rotate which eventually pulled the wires out of the plug in the hub.
Not a big problem.
That's a more concise explanation than I could manage. The adaptor is 100mm exactly whilst the hub is 99.8mm it took me a while to figure it out...
Not a big problem.
Ok, so I understand this properly (it might be important later on...), the adapter goes right through the hub, unlike the Hope ones which are just caps in the end of the hole. The adapter bit is too long, so take a bit off (file or lathe) the end and it's all good?
It would probably be clearer if I knew what the adapter looked like, then might have understood betterer.
Taylor
Post by Taylor »
Similar to this
Mart
Post by Mart »
Postie dropped a big box from CRC that contained 2 pair of socks (Endura merino winter ones)
And eBay parcel with a heart rate strap. Midweek training's getting more sophisticated
The postie brought me 8 phenolic pistons for my ailing Hope Mono M4 brakes - carefully de-siezed just prior to There 'n' back by Stu (and ta muchly for your hard work dude), but now stuck solid again in the garage...
Also picked up one of those Hoep ceramic BB's from Halfords on Monday. The 83mm shell is a bit short for the Puffin though, but no matter as the EBB is effectively sealed from water ingress except through the bearings themselves. We'll see if the Hope bearings last more than 120 miles before sounding rough like the bog-standard ones in there at the moment did :?
Mart wrote:Postie dropped a big box from CRC that contained 2 pair of socks (Endura merino winter ones)
Did you get a seal kit as well? Whilst you're swooping pistons its worthwhile. Trust you've also got the tool / a plan to get the bite caps out? Are the M4s the ones that have two sizes per caliper ;)
Seal kits are arriving separately courtesy of slarge (thanks buddy). I have the tools too and some special rubber-based grease that hydraulic fluid doesn't dissolve, so it'll be a proper job 8-)
I nearly pulled the trigger on some XTR trail disc brakes, but at a tenth of the cost plus some workshop time, 8 round bits of plastic seemed easier to justify...
Seal kits for me too. Fork ones from RWC though.
If you do change your mind ian, the XT's perform that same (as much as I can tell) for a fraction of the cost of xtr's
I have 2 sets of XT's, both are excellent and have been for some time now.
Not that I dont want XTR too though...
