No I'm not ever returning to my triathlon days. It's for the TD bike.
I'm looking for something a bit more specific than just clip on bars - specifically ones where the arm rests are adjusted on the extensions, not fixed to the bar clamp. So, something along the lines of a Profile Designs T1, T2, T2+, or T3.
They'll be getting gutted with another set of extensions I have - so doesn't matter if the extensions are straight/J/S/Double kick.
So, what does anyone have?
Wanted: Aerobars - bear with me...
Re: Wanted: Aerobars - bear with me...
Had a look at the selcof ones from Px? I bought some but I'm scratching my head as to how to fit them to Jones bars without bringing on nausea.i might just settle for double wrapping the Jones Loops for extended use instead.
Narp, I specifically want the armrests to be mounted on the extensions - positioning reason.johnnystorm wrote:Had a look at the selcof ones from Px? I bought some but I'm scratching my head as to how to fit them to Jones bars without bringing on nausea.i might just settle for double wrapping the Jones Loops for extended use instead.
Affixing to Jones is fine, once you don't have the front part kicked up....
Are these of any use?
We’re gonna need snacks
#TakeLessBike
#TakeLessBike
I mean nausea from the look....GregMay wrote:Narp, I specifically want the armrests to be mounted on the extensions - positioning reason.johnnystorm wrote:Had a look at the selcof ones from Px? I bought some but I'm scratching my head as to how to fit them to Jones bars without bringing on nausea.i might just settle for double wrapping the Jones Loops for extended use instead.
Pickers - sadly not - again, arm rests on the mounts to the bar - but also, going under the bar with the extensions won't work with my front bag. Thanks though!
