Clear out - Road, Gravel, Tour, MTB...Carbon wheels, tyres, dropper....
CJR61
Post by CJR61 »
Clear out – MTB, Gravel and Road – Carbon wheels, tyres, dropper…..
Roval Control SL SCS Carbon 700/29 wheels
Beautiful wheels in good/very good condition.
700/29
ID 22mm
OD 30mm
Taped for tubeless
Some small superficial scuffs and marks but overall very good condition.
10mm front axle, 12mm road rear (I believe you can change these axles to other standards)
Front hub very smooth
Rear hub has a slight notch feeling in the hands but nevertheless spins and spins and spins. However, once mounted and axle compression applied they feel super smooth so think this is a nuance of the hub that needs compression. I’m pretty sure these are DT Swiss 240 hubs rebranded.
Weight 1.40kg
£550 collected £600 posted - open to offers
2 x Shimano RT86 6 bolt rotors 160
Good condition
£40 posted the pair
Road tyres
All used but life left
S-Works Gripton – single – £15 posted
Gatorskin 25mm – 2x pairs – £30 posted each pair
Robaix Pro – single – £15 posted
Specialized S-Works Turbo – pair – £30 posted
Schwalbe Durano Plus Etape – pair – £25 posted pair
Schwalbe One – pair – £25 posted
Lifeline mudguards
Brand new never fitted
50mm (38-47mm tyres)
£20 posted
Ultegra 11-32 cassette – 11 speed
£35 posted
Keo cleats – new – 2x sets – £7 per set
Brand X 27.2 90mm dropper
Stealth
Very good condition
With remote
£85 posted
29er tyres
Conti Der Baron Projekt – 2.4 – £30 posted
Conti Trail King Black Chilli – £25 posted
Maxxis Minion DHR II 2.4 – 3C MaxxTerra Exo – £15 posted
Pictures: https://share.icloud.com/photos/009jaXI ... cmk-9tUscw
Based in Redditch or Coventry and happy for collection. Bartering, haggling, heckling and sledging is welcome.
Chris
CJR61
Re: Clear out - Road, Gravel, Tour, MTB...Carbon wheels, tyres, dropper....
Post by CJR61 »
Open to offers, all gathering dust!
Al
Post by Al »
Any 28mm road tyres in there?
Al
Post by Al »
CJR61
Post by CJR61 »
The Roubaix says 700x25/28…clearly it’s being indecisive!
All the rest 25 I think sorry
CJR61
Post by CJR61 »
Sorry made a mistake with the wheels
12x100 front (15mm axle so could be 15mm hub with correct end caps)
12x135 rear but SCS spacing - Specialized concept store say you/I need a NDS 142 end cap and that should make it a normally spaced 142.
Open to offers so if you’re interested don’t be shy! Would like them gone.
Chris
