WTD Surly Snuggnut
WTD Surly Snuggnut
Hi All,
Don't suppose anyone has a Surly Snugnut going spare? Or can recommend another alternative for use with a SS Karate Monkey?
Cheers,
Sam
Cheers,
Sam
Re: WTD Surly Snugnut
I've already got a tuggnut but need a snuggnut to work with the 12mm thru axle
Re: WTD Surly Snuggnut
Right you are - I'd not come across them but I still live in the dark agesI've already got a tuggnut but need a snuggnut to work with the 12mm thru axle
Came here to correct a spulling errur and instead learnt something. Most excellent. Though I have no need for a Snugnut as my SS bikes are all from the dark ages
I considered this but looks the tuggnut design with 2 holes won't quite work on the newer dropouts
I was also shocked when my trusty tuggnut didn't fitBearbonesnorm wrote: ↑Sun May 08, 2022 4:59 pmRight you are - I'd not come across them but I still live in the dark agesI've already got a tuggnut but need a snuggnut to work with the 12mm thru axle
I use these in the 10mm version - cheaper than the Surly and you get a pair
https://www.tredz.co.uk/.DMR-Chain-Tug_ ... ium=648417
It does work, singlespeed on the driveside, I drilled mine. The snuggnut is neater though
(If you wanted to use it to adjust wheelbase on a geared setup, you'd need to trim the bottle opener off the bottom too, at least with shimano derailleurs.)
Thanks for the info. Which hole did you end up drilling? I guess it may depend on the chain length you are running?FLV wrote: ↑Mon May 09, 2022 8:12 amIt does work, singlespeed on the driveside, I drilled mine. The snuggnut is neater though
The same one used in the pic stu posted above.samwise wrote: ↑Mon May 09, 2022 9:01 amThanks for the info. Which hole did you end up drilling? I guess it may depend on the chain length you are running?FLV wrote: ↑Mon May 09, 2022 8:12 amIt does work, singlespeed on the driveside, I drilled mine. The snuggnut is neater though
I wanted a snuggnut as its much neater, but already had a tuggnut so went for it
