WTD: Shimano 10sp RH displayless shifter - SLX, Zee etc
Anyone got owt in reasonable condition before I buy a new un? Need it by the middle of next week though
- Bearlegged
Re: WTD: Shimano 10sp RH displayless shifter - SLX, Zee etc
I've got an SLX SL-M670, but it has the display. Looks like there's a couple of screws you can remove to take it off, but I'm slightly loathe to start disassembling it! Let me know if it's any use.
I believe you can remove the window but you need another to cover the hole. Do you have the little cover?
- Bearlegged
I don't think I do, soz.
I have a zee sans display stu in good nick
How much do you want Phil?
Swap for a luxe hexipeak? (plus 140 quid)
Seriously, I'll just stick it in the post Stu but it may be late next week as I'm off oot and aboot for the next few days or so. Is that too late?
EDIT actually just realised I need to go to the co-op tomorrow so will post it then.
That's smashing Phil and I'll see you right in Oct in that case
What with a really easy BB200 route?Bearbonesnorm wrote: ↑Fri Sep 17, 2021 8:15 pm That's smashing Phil and I'll see you right in Oct in that case
I'll do you a special oneWhat with a really easy BB200 route?
