FS: Luxe HexPeak. SOLD
I have a brand new Luxe Sil HexPeak F4 that I don't require. After the initial purchase I put it up the once but never used it after that. There's also a Luxe adjustable alloy pole with it, although that isn't new.
If you were to buy the pair now it would cost around £230 but these are yours for £170 delivered. Plenty of details about it here https://www.backpackinglight.co.uk/shel ... 9-138.html and it looks like this. I believe a double inner is also available for them.
Re: FS: Luxe HexPeak.
Hi Stu
On the vid on that link the chap says its a bit tight for an over 6 footer. On the description it goes on about the latest version being longer and a bit taller.... Is this one the longer and taller one?
Phil
Phil
I don't know Phil. Any clues without putting it up?
According to the website the new version has an internal floor length of 233cm. As far as I can tell the one the guy puts up in that vid is the older version which should be 8cm shorter.....
Sorry to be a pest....
The later bigger one was called the V4A Stu, you might be able to find that on the bag, I can't remember if it's printed on mine, the original smaller version was just called the V4
Edit: just checked mine Stu and it does say v4A on the end of the stuff sack
No, can't see any mention of 'A' but I've just laid it out (not put it up, it's raining) and the floor length of the inner is around 7'.
Hi Stu, that looks like its the older one and will be a bit too short for what I'm looking for so I'll pass. Thanks for the extra info and sorry for hassling you!
Phil
Phil
No trouble Phil but let me know if I can tempt you at £150
Bearbonesnorm wrote: ↑Tue Aug 24, 2021 1:31 pm No trouble Phil but let me know if I can tempt you at £150
I'll think about it.... I could pick up at the BB as well.....
If you did want to do that, I'd knock another tenner off Phil.I could pick up at the BB as well.....
