WTD: WOHO bag stabilizer
I'm keen to try one of these, primarily to carry water on my fatbike in the winter and thus avoid taking a backpack. As far as I can see, they're just not available (other than the Brooks version). Maybe someone has one and no longer uses it?
Re: WTD: WOHO bag stabilizer
I have one I don’t use that I could get in the post next week.ScotRoutes wrote: ↑Thu Jul 08, 2021 2:21 pm I'm keen to try one of these, primarily to carry water on my fatbike in the winter and thus avoid taking a backpack. As far as I can see, they're just not available (other than the Brooks version). Maybe someone has one and no longer uses it?
The reason I don’t use it is because it’s pants.
The material it’s made from has all the strength of cheese. It got pretty bent up in its one and only use.
I don’t remember how much I paid for it but it was way too much. Cover the postage and put some pennies in the Hungry Bear and it’s yours
PM if that hasn’t put you off
- Specialist Hoprocker
Someone posted one of these the other day as a alternative:
https://www.amazon.co.uk/gp/product/B07 ... 2A9M&psc=1
Ah, cheers. That would rule out use of a seatpack though.
I think the chap who posted it said that he used it with a seat pack but not the bottles (as the mounts are facing the wrong way). I wondering if some careful heating and twisting could bend the ends 90ish degrees outwards to essentially replicate the WOHO one. For £9.99 I was thinking of having a go.
Could you not source some 90 degree brackets perhaps like thisSpecialist Hoprocker wrote: ↑Fri Jul 09, 2021 11:51 am I think the chap who posted it said that he used it with a seat pack but not the bottles (as the mounts are facing the wrong way). I wondering if some careful heating and twisting could bend the ends 90ish degrees outwards to essentially replicate the WOHO one. For £9.99 I was thinking of having a go.
https://www.bedslats.co.uk/bed-90-degre ... kh-h-130mm
*Bracket in post above as example rather than one to use :)
- BigdummySteve
I put two bottles in my down tube, works a treat
viewtopic.php?f=7&t=20085&p=264202#p264202
