Has the XD compatible freehub system. I've owned for about 2 years and before that O believe they came off Colins brandnew bike. Sale is for the wheelset only (no tubeless valves, no tires, no disc rotors).
Rear bearings feel smooth and the freehub nice ant ratchety. The front bearings feel a bit gritty to the touch but no play in either wheel AFAIR. So I'm confident you've got plenty miles left before needing to touch any bearings. The grittiness in the front seems to be the axle ends just need popping off and wiping down them and the tops of the bearings.
Price as selling (wheels only) is £210 delivered.
Price with tires still on and at 14ish psi (it's fresh sealant in there and not the evil Stans, so no vulcanized jamjar effect when you get em off) but no rotors, £280
FS: DT SWISS M1700 boost wheelset (only)
Last edited by redefined_cycles on Mon Apr 19, 2021 11:16 am, edited 1 time in total.
Re: FS: DT SWISS M1700 boost wheelset (only)
I've sent you a PM
Ta Marty. I might hold on to em for the mo. Soz
No probs. Let me know if you change your mind and want to re-home them.
Will do. Thanks Marty...
