WTD - silver rim brake road (dynamo?) wheels
Bit of a longshot but before I spend ££ and wait weeks. I'm after a silver rim brake QR wheelset suitable for a road/audax bike, dynamo front ideally but if not may still be of interest - if the rims are readily available I can get a dyno front made up later. 9-10s freehub is OK, no need for 11s.
Also an option is a pair of NOS silver rims, if you had some DTs hidden away? Open Pros are an option but a bit skinny really.
Re: WTD - silver rim brake road (dynamo?) wheels
If you don't get any better responses, I have some 36H Open Pros you are welcome to (postage being the only thing). I also have 36H XTR disc hubs. I'd want something for them, just not thought of a price.
Kind offer, thanks Colin. I expect I'll stump up for a new build on a SON in the end if there's nothing close about S/H wheelset-wise, it's the build that will slow it all down. I really should have learned to build wheels by now.
It's suprisingly difficult to find a wheelset to this sort of spec yet if I wanted a £1200+ set of deep section carbons I'm spoiled for choice. Bonkers. Spa Cycles have some options but are still a bit limited on rim range.
I have a 2nd hand sp dynamo hub on silver Alex rim. I could never get any output from the dynamo, but the spokes and rim are good. Yours for postage
Oh, it’s front only and silver
Did you say what size James? If it's 650, there's some 32 hole SunXCD rims here - polished and a bit retro.
https://www.planetx.co.uk/i/q/RISXCDRR/ ... minium-rim
Tempted to take you up on that Steve and bung you fair £ if it can be got working but it sounds like you've tried? If so it'll be a rebuild and hard to get a rear rim to match so I'd be better stumping up for a new pair. Thanks though, appreciated.
I didn't did I.. 700C. Those SunXCDs look nice, had only seen mechs and chainsets from them so far. I've got my eye on H Plus Son TB14s in classic CD grey ano but it's getting pricey. Still, would look lovely on a skinny steel bike.Did you say what size James?
Just looked at those Stu, and they're 650a which I think is a different outside diameter for the tyre bead?
Sorry, I obviously didn't read it properly, I just saw 650 and assumed.and they're 650a
I'll check to see which rim it is, and if there's the same on ebay I'll ping you a link so you can be a tart and have matching wheelsjameso wrote: ↑Thu May 21, 2020 6:56 pmTempted to take you up on that Steve and bung you fair £ if it can be got working but it sounds like you've tried? If so it'll be a rebuild and hard to get a rear rim to match so I'd be better stumping up for a new pair. Thanks though, appreciated.
I have a front dynamo Shimano DH - 3N71 on rigida sputnik silver rim. Has a spa cycles sticker. £25 plus postage costs?
I might be able to get an Alex rim via our OE supplier so could be good to know. I'm not exactly a dab hand with the Evo meter though so if you've tested out the hub and it's truly dead it may all need more time than the wait to get a set build new.
Ben, that's a sound wheel, a bit heavy duty for this bike but perfect for a proper tourer and Spa have rears to match. Tempted, will PM soon if the new option's going to take long. Thanks.
