This is my custom built Shand 29+. Based around a 470mm rigid fork (I used an On one Fatty carbon, also for sale.) or 100mm suspension.
Reynolds 853 and Columbus stays iirc. It will take a full 3" tyre on 50mm rim.
I actually used 27.5+ most of the time as the BB is fairly high as 29+ and preferred it that way.
Roughly a size small. It has a PF30 BB so can be fitted with an EBB as pictured. Frame buyer will get first refusal on the EBB if they want to go SS or Rohloff. It has a Rohloff dropout on the NDS so is ready. Dropouts are Paragon so can be swapped for allsorts if required. Split stay so could go belt.
BB is £50 if required.
Condition is excellent, just a few paint chips.
Pics here, including geometry. https://www.flickr.com/photos/60407271@ ... 4150017087
IMG_20200503_190048
Shand 29+ Frame £250. SOLD.
Re: Shand 29+ Frame £250.
Very interested- how tall are you?
Should have mentioned in the ad, it's 170mm rear spacing and 100mm BB.
Showing interest as well ,well actually it’s my eldest son but he’s not on this fourm
I also have a Hope Fatsno rear hub for this, built onto a Halo 50mm B+ rim, all set up tubeless.
The QR endcaps have gone AWOL, but if I don't find them they can be bought easily enough.
I have an unused set of E13 cranks to suit also, but they are 30mm axle so would not work with the EBB. If you want to run derailleur gears then not an issue.
Pm sent
