Quarantine Clear out
Drliamski
Post by Drliamski » Fri May 01, 2020 12:31 pm
So decided to have a sort through the spares boxes. AGAIN
Bike parts sale.
Please get in touch if you want photos.
NEW BITS
Salsa Rustler Riser Handlebar 31.8 750mm width Black Rise: 20 Back Sweep (deg): 11 Upsweep: 6
£30
SHIMANO QR 6 bolt Deore front hub HB-M525A VIA?
SALSA lip LOCK 30.0MM GREEN
£15
Hope pro 4 hub endcaps 20mm Boost 110mm compatible
£10
SHIMANO Deore front mech FD M590 and shifter GOOD CONDITION
£20
TEKTRO R559 LONG PULL CALIPERS IN SILVER.
GOOD CONDITION
£24
Tektro RL720 Series Brake Top mount Levers 22MM?
£13
avid BB7 MTB CALIPERS
WELL USED was working fine till upgraded. Will include a load of part used pads
RITCHEY WCS bar ends 80mm long, white £9
SRAM x5 2 speed shifter £7
FWE AVID elixir brake pads, semi sintered NEW £6
AZTEC AVID elixir brake pads, semi sintered NEW £6
OLDER LISTINGS
Wheelset 650b Stans Crest ZTR on superstar switch hubs, qr/20mm thru, and 12x142 rear.
Basically unridden, a couple of marks on the stickers from fitting tyres
£150 Provisionally sold
Raceface Turbine Forged, in good condition.
175mm x 94 BCD Compact Drive - Square Taper - 5 Bolt. £50
Salsa Woodchipper, 460 mm, marks from bar tape but pretty good condition £35
Alpkit Bombers. Good condition, prefer the Ritcheys £20
On one Marys in white. Quite marked £10
Fizik Arione carbon rails, quite work but serviceable. £7.50 SOLD
Hope 38t 104bcd chainring, good condition £13
Nukeproof Warhead headset EX44-40-b5 Bottom Cup £10
Shimano SLX Centerlock qr front hub HB-M665 bit scratched £10
Shimano ULTEGRA PD-6610 good condition £30
Shimano pd-m505 £10
Shimano pd-m737 £15
Shimano fd-m590 34.8 mech £10
Shimano rd-m510 rear mech £15 sold
Tektro R200 Brake Levers Pair Black £15 unused as wrong pull ratio SOLD
Sram Rival Rival1 Type 2.1 Long Arm 11 Speed Rear Derailleur, note cable barrel adjust not working hence price £25
robbie
Re: Quaranine Clear out
Post by robbie » Fri May 01, 2020 12:43 pm
Interested in the Fizik Arione carbon rails
Can you send me some pics by email to roblyall@msn.com
Drliamski
Post by Drliamski » Fri May 01, 2020 1:20 pm
Pics sent
Dyffers
Post by Dyffers » Fri May 01, 2020 1:29 pm
If this is black and NW I'm interested: Hope 38t 104bcd chainring, good condition £13
Also interested in the Arione saddle if the above falls through.
Drliamski
Post by Drliamski » Fri May 01, 2020 3:09 pm
No its single width teeth afaik.
Dyffers
Post by Dyffers » Fri May 01, 2020 3:35 pm
No problem, I'll leave the chainring then, thanks.
Squirtymcfilthy
Post by Squirtymcfilthy » Fri May 01, 2020 4:53 pm
hi, are the mary bars 31.8 or 25.4 clamp size please.
Drliamski
Post by Drliamski » Fri May 01, 2020 5:14 pm
31.8 :ugeek:
PaulE
Post by PaulE » Fri May 01, 2020 8:44 pm
If the saddle isn't yet sold, I'll have it please.
Retiredtester
Post by Retiredtester » Fri May 01, 2020 9:31 pm
Is the rear mech clutched?
Drliamski
Post by Drliamski » Sat May 02, 2020 8:03 am
The SRAM mech is but the 9 speed shimano is not AFAIK. No such thing as a 9 speed clutch mech?
Drliamski
Post by Drliamski » Sat May 02, 2020 8:04 am
Error in the listing as its not carbon rails but carbon reinforced?
I can send you some photos if it helps?
Best
Liam
PaulE
Post by PaulE » Sat May 02, 2020 2:08 pm
No need, so long as it's useable. I've got a new tandem on the way and suspect that the seat on it will be too big and squishy for comfort.
Drliamski
Re: Quarantine Clear out
Post by Drliamski » Sat May 02, 2020 6:52 pm
No worries, I can probably post Monday.
PaulE
Post by PaulE » Sat May 02, 2020 9:50 pm
message me with how you'd like paying and I'll send it over. No rush at all on delivery, so just post it when suits you.
substandard
Post by substandard » Mon May 04, 2020 10:47 pm
Interested in the sram mech if it’s still available?
Drliamski
Post by Drliamski » Mon May 04, 2020 11:16 pm
Sure is. Send me an email address and I'll get some photos to you.
L
restlessshawn
Post by restlessshawn » Thu May 07, 2020 8:51 am
Can you send me a couple of pics of the R200 levers please? smcfarlane at gmail dot com
Drliamski
Post by Drliamski » Thu May 07, 2020 10:29 am
Will do mate
Drliamski
Post by Drliamski » Sat Jun 06, 2020 1:50 pm
Updated with sold bits. :cool:
Drliamski
Post by Drliamski » Thu Jun 25, 2020 1:50 pm
Some new additions!"
fontmoss
Post by fontmoss » Thu Jun 25, 2020 2:09 pm
Please can I get some pics of salsa rustler and chipper bars please? Is the Hope chainring an assymetric? Ie fits shimano road cranks
Fontmoss at gmail.com
Drliamski
Post by Drliamski » Thu Jun 25, 2020 2:56 pm
Pictures sent mate,
do you mean 110 bcd? Hope is 104 iirc
