WANTED *Now sorted* Pump mounting bracket
mfezela
Post by mfezela »
After decades, literally, of exposure to the elements my pump bracket has expired. I knew the plastic was brittle, so treated it carefully, but earlier today it said enough! Can't seem to buy this without an accompanying pump.
Anyone got a spare?
Regards,
Jan
(18.9 KiB) Downloaded 342 times
Re: WANTED * Pump mounting bracket
I think I can sort that!!
Edit: I have a couple of Specialized pump brackets. Seem to be 26mm internal so might do the trick. I can stick one in with the other bits next week?
one from a lezyne pump
8.3 cm long
25,5 MM circumference [ for pump holding ] so that is the minimum size
It also has a velcro securing strap attached - one arm is broken* - each securing bit has 2 arms each side it so i t should have 8 and it has 7 - never caused me a problem and as i said it got a strap anyway
Any use?
* I stll use one and i cut the brackets on one side -bag clearance nd that holds the pump without isue
PM if you want pics etc
mfezela
Post by mfezela »
That will do very nicely. Pop it into the box ;-)
Regards,
Jan
Thx for other replies.
I'll not seal the box yet :lol:
macskive
Post by macskive »
Are you sorted? I probably have something suitable in my garage.
mfezela
Post by mfezela »
Yes, all sorted. Thx to ScotRoutes
