SOLD
I used these to cycle to Morocco late last year. My needs have changed, and I don't see myself needing the extra capacity of panniers any time soon. I thought about keeping them for commuting, but I damaged my rack recently and I'm moving, so time to go methinks.
Despite travelling several thousand km through Autumn and Early winter they're in surprisingly great nick. There is a small gash at the bottom of one, which I made before even leaving. I forgot to tape it, but it never widened (I did keep my quilt at the bottom of that one, so it spread the pressure). It's the size of a 20p coin, I've taken a picture of it.
It has an easy on/off with just the handle. The bottom of the pannier is kept secure with a magnet (fine on pavement and gravel roads, but not a winning design choice with bumpier or single track type stuff). Within those limitations it makes for a quick and easy bag.
I don't have both original shoulder straps, but I have a spare from another bag I can throw in.
When initially setting up, I overtightened the bolts and went through the back of the magnet fasteners - this hasn't gotten any worse since the ride to Morocco.
They have reflective stripes.
I cut one of the little organisers out because 1) I had no need for it in 2 panniers 2) being a gram weenie
I like them for their simplicity, watertightness and smaller size. Which means they're a hard sell with the traditional bike tourist crowd! So maybe someone here might like them for commuting or less technical trips.
They were £110 new. I'd be happy to sell them for £40+shipping.
Some idea of the general wear.
The gash that didn't grow.
Organiser cut out.
Magnet fastener things.
More gratuitous shots
[SOLD] Set of Chatreuse Shield Thule Pack n Pedal Panniers (14l each)
Re: Set of Chatreuse Shield Thule Pack n Pedal Panniers (14l each)
Here's the Thule specs:
• Protected against splashing water - protection against dust (IP64)
• Volume: approx. 14 l
• Dimensions: approx. 25,4 x 13,97 x 31,12 cm
• Material: nylon 420D
• Weight: approx. 700 g (according to my "barbie bakes" scales, the weight per pannier is more like 850g)
Including: 2 Thule Pack ’n Pedal SHIELD PANNIERS with a volume of 14 litres
