As above in medium will suit rider 5’8”-6’, will also include brand new Hope 1 1/8th headset(still in packaging).
Would make a superb bikepacking bike as a rigid with the Salsa firestarter fork or a lovely XC hardtail with a nice 100mm Reba.
Here’s what Salsa say:
El Mariachi is the 29er hardtail for slaying singletrack or getting your bikepacking trips on. Simple, comfortable, and efficient, the frame features Alternator dropouts for thru-axle, geared, singlespeed, or Rohloff hub setups, should the spirit move you. Run your El Mariachi with suspension, or set it up with our Firestarter Carbon fork to truly customize your ride. You can even throw our Alternator 135 Rack and panniers on for some off-road touring and staying out later than originally planned.
* Chromoly steel Kung Fu tubing frame with Alternator dropouts
* Design Wheel/tyre Size 29 x 2.1 to 2.4"
* Suspension Fork Length (Travel): recommended 100mm
* Headset-Upper: ZS44 Headset-Lower: EC44
* Seatpost: 27.2mm
* Seat Collar: 30.0mm (included)
* Front Derailleur Type: 3x or 2x, top-pull only
* Front Derailleur Mount: High direct mount (26mm offset) via 31.8mm clamp Problem Solvers Bracket
* Bottom Bracket: 73mm BSA, threaded
* Crankset: 1x: 32t max standard MTB, 2x: 40/28t max standard MTB, 3x: 44/32/22t max standard MTB
* Rear Brake (Rotor): 51mm standard (160 to 180mm)
* Rear Spacing: 135 x 10mm quick-release, 142 x 12mm thru-axle
* Bottle Mounts XS and SM = 1, MD to XL = 2
* Color: Ruby Red
Salsa link https://salsacycles.com/bikes/archive/2 ... hi_gx_2x10
£350.00 ono shipped.
I also have matching brand new Salsa stem, brand new Selcof flat carbon bar and brand new Crankbrothers Candy 7 pedals which can be negotiated for with the frame.
Email fudge9202@googlemail for pics
BNIB Salsa El Mariachi frame (M)
Re: BNIB Salsa El Mariachi frame (M)
FWIW, I'm 5'7" and my El Mariachi was a medium so rider height will come down to preference.
Yes your absolutely right Scotroutes , I just quoted from the Salsa website.
