Way OT: Ender 3 Pro 3d printer
slackman99
Post by slackman99 » Fri Oct 25, 2019 5:53 am
Ender 3 Pro.
I’ve replaced the build surface with glass as the top surface of the original magnetic build surface delaminated when trying to remove a particularly stubborn print. The glass is flatter and provides a smoother finish. If you wanted to go back to the magnetic build surface option you need to buy the surface again (about £10) and just take the glass off.
I’ve added a bootloader to the board and uploaded a proper version of the Marlin firmware into it which had the thermal protection enabled along with various other options that Creality hides in their version of the firmware.
There’s a few 3d printed mods (orange items in the photos) and I’ve also added a geared BMG clone extruder. The original extruder is also there if you wanted to change back and it’s about a 20 min a job to do so with an Allen key and a change to one of the settings on the machine to account for the different gearing ratio.
It’s not had much use and is currently taking up room on my office desk at home.
I'll sort out pictures tonight as my Flickr account is playing up.
Based near Northampton. Looking for £135
PaulE
Re: Way OT: Ender 3 Pro 3d printer
Post by PaulE » Fri Oct 25, 2019 7:17 am
What diameter filament does this use? I've a damaged 3d printer at school and if this will run on the leftover spools we have then I would be very interested.
slackman99
Post by slackman99 » Fri Oct 25, 2019 7:31 am
PaulE
It nominally takes 1.75mm dia filament. I think you can change it to take other filament diameters but that would need parts changing.
So 1.75mm is the short answer :)
PaulE
Post by PaulE » Fri Oct 25, 2019 12:11 pm
I'll see what we've got, ta
slackman99
SOLD: Ender 3 Pro 3d printer
Post by slackman99 » Mon Oct 28, 2019 12:47 pm
Now SOLD
